Archive
I purchased Kaspersky Pure 2.0 from E-store and when trying to install it, I receive the following error over and over again. I am using windows vista Premium 32 bit version on my computer and I find that I have more than 300 GB free space. I disabled my firewall settings temporarily and closed all other running programs prior to the installation. I clicked on the link provided by E-store to download the installer and saved it on my desktop. After closing the browser I clicked on the exe file to launch the installation wizard and proceed with the...
Read more
I had installed the 30 days free trial version of Kaspersky Internet security 2014 on my pc a few days back. I had no issues with the downloading of the installer or the installation process. And everything was working fine till yesterday evening. However, today when I turned on my PC I get this message from Kaspersky stating that a previous application launch has failed? I tried clicking the ‘Send’ button in the error message but that gave me a message sending failed error. I have windows XP installed on my machine. I attempted deleting the temporary files using...
Read more
Hi Everyone,
I receive the following error message with only an error code 0x80000240 when activating Kaspersky Pure 2.0. And I find the following message on checking the Licensing window "Impossible to verify the database license agreement”. I tried restarting my computer and tried activating again. After several attempts failing to give any improvement in the situation, I attempted to update the anti-virus databases of Kaspersky Pure 2.0. I chose update from Kaspersky’s context menu and was able to complete the same without any errors being reported. But when I try activating again after a system restart, I still get...
Read more
Hi Friends,
I am trying to save an audio file in Finale 2012 and I get an error message when attempting to do so. I had no issues with saving a new document made in Finale. But when I've opened an audio file created using an older version of Finale (2002), I am not able to save it as an audio file. The file opens without any issue but I am not able to use it as a 2012 file. Then I had a go at updating old files and for this, I opened the old file in 2012 and...
Read more
I recently purchased and installed Sibelius 7 on my computer. The installation completed smoothly without any issues. However when I try to start Sibelius 7, it gives me ‘The library Sibelius 7 Sounds cannot be found’ error message. I reinstalled it and the outcome was the same. I even attempted manually pointing it to the correct folder. But this too did not give me any different result. I did not change the sounds folder or anything soon after installation, I tried launching the software and I get this error. I attempted to verify that I have installed all four...
Read more
Hi All,
I recently installed Sibelius 7 and when I tried to playback using the Sibelius Sounds library I am getting the following error stating that there has been an error loading the sample into player. To resolve this issue, I tried running the Sibelius & sounds installer from Sibelius 7 program DVD and also updated to the latest version of Sibelius 7 sounds library from the official website. Then I tried running the playback again. But still I cannot hear any sounds. I also ensured that the sounds folder contained a list of each of the following instrument families:...
Read more
I am trying to install VMware Player 6.01 on my Windows 8.1 PC. But I am having a syntax error and I can't continue with the installation. Choosing on the Yes button will just close the error but it will randomly appears again. Can someone tell me what to do? Thanks!
The error message I am receiving is:
An error has occurred in the script of the page.
Line: 1089
Char: 7
Error: Expected ')'
Code: 0
URL: file:///C:/Users/Dog'z/AppData/Local?Temp/vmware_1391621502/index.htm?lang=1033&locale=1033
Do you want to continue running scripts on this page?
Yes     No
Read more
I am attempting to launch PCmover and I get this error reporting an error preventing the software from working and quit the program. The error message does not give me any info regarding what caused the error only a hope that windows would find a solution and then notify when a fix is available. I have used PCMover a couple of times after its installation and never faced any issues. Now whenever I try to launch PCMover, I end up with this error. I tried uninstalling and installing PCMover back again. But this did not resolve the issue. I...
Read more
Hi All,
I have been attempting to activate AutoCAD 2014 on my computer and the following error message comes up during installation. I tried installing a couple of times after disabling my antivirus software. But this did not help me in any way. Then I attempted remove this installer and downloaded and saved a fresh copy of the installation file and then tried again. Even then, installation fails without activating and reporting this same licensing error. I have administrative access on this windows 7 machine. What else could be causing this error? Is there a patch or work around to...
Read more
Hello All,
I tried creating a new title block on Vectorworks Architecture and when I try to save it to the Title Blocks Libraries, I am prevented from doing so by an error message that says the file is in read only mode and should a copy be created with a new name. The file was not set to be read only at any point. And I am the only user on this machine and have full administrative access. Do we need to create a separate library folder to save the custom title blocks? I did not find this as...
Read more
