Archive
Hi there,
I am in the middle of configuring my system, I have a windows 8 64 bit, 1GB RAM operating system. The problem is I am not able to set the CD-ROM drive software successfully, it failed in driver installation. How do I set the device? How do I install the device drivers? Thinking of the problem might be the device? Help please.
Error:
Device driver software was not successfully installed.
Please consult with your device manufacturer for assistance getting this device installed.
Read moreI am new to Windows 8. Yesterday, I downloaded an app and it works just fine. However, when I tried to download some apps again today, an error occurred that says, "Something happened and this app couldn't be installed. Please try again. Error code: 0x8024001e". When I hit the Try again button, it will just show the same error message. And clicking on the Cancel install will close the error. How can I fix this?
Hello tech Savvy,
When I attempt to setup the Cypher, I ended up with an error message and it failed to setup Cypher. It went pretty good to some extent in installation, the problem appears while registering the file. I think some dll files are missing, how do I fix them? Please help to resolve this error. Thanks in advance.
Error :
Cypher Setup
An error occured while registering the file 'C:WindowsSystem32MFC40.DLL'
Read moreI want to install the latest update of Evernote software. However, every time I tried an error will pop up:
As this
Evernote v. 4.6.6
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2732.
I am stuck with the installation and when I tried to uninstall Evernote, I was unable to. How can I fix this please?
Read more
I am getting this wired error message again and again I think a loop is set in there. When I try to install the parallel tools I get this error almost towards the end. It gives me an options to select don’t install or install any way. I was trying to click install any way option, but this is not preceding further. I tired like couple of times, what might be the problem? I tried this from a licensed website. Help to resolve this error.
Error :
Windows can’t verify the publisher of this driver software.
Read moreHello hardware Professionals,
When I try to update the Daemon tools driver I got an error first and this error triggers for all the drivers whatever I am updating. For your information I update my operating system and application in regular basis. And also I tried the automatic driver update, but no luck. Do you have any helpful suggestion? Please provide me some assistance in setting up the drivers. Thanks.
Update Driver Software – Ethernet Controller
Windows encountered a problem installing the driver software for your device.
Windows found driver software for your device but encountered an error while...
Read moreHey friends,
When I am in the process of installing the Borland database, I got to end up with this error message. This error triggered when I am trying to connect the BDE to SQL Server database. This error initiates me to re-install the BDE but now I am stuck up here. Is there any problem with the windows registry? How I can solve this error? Help please.
Error :
BV7 – QSL Labels
An error occured while attempting to initialize the Borland Database Engine (error $274F)
Read moreHowdy,
I am getting this error message and I got stuck up here not able to proceed further. This error message triggered when I am trying to install the Lexia, error stating reactivate to restart the installation. So tired by restarting the system and also try by re-installing Lexia, no luck error persists. Doubt whether the system isn’t compatible to install Lexia. I tried in Windows 8 operating system 32 bit, Help please. Thanks.
Error :
Error Lexia
Error during installation of Lexia. You have to reactivate to restart the installation.
Read moreHello expert friends,
I tried to sync the BlackBerry with the desktop calendar on the computer using the BlackBerry Desktop Software ended up with the synchronization error. For you information, it is a wired synchronization and software version I used is 7.1 and BlackBerry Strom 9550 smartphone. Do I need to upgrade any of the one? Is both are compatible thing? Help me to sort the problem. Thanks.
Error:
Blackberry Desktop Software
Synchornization Error
CRRecurringl::AddExpectionRecord: Could not set exception date in record.
Read moreHi Tech experts,
I got this HP imaging device, works great. The problem with HP is I cannot perform the scan with an image. I restarted the program and also the reboot but nothing worked. No other program is using the device, then what might me the problem? I does not have the wireless access, might be problem with the USB port? Help me to find the cause of it. Thanks.
Error:
HP Scanning
The scan cannot be performed because another program has control of the HP imaging device. Try the following steps. After each step, try scanning again.
