Archive
I  am having trouble signing in to iTunes Store. It is telling me to check my connection. I tried to browse the web and launch other sites and it opens without issues. This is to check if there is a problem with my connection. Can someone recommends a fix for this? Thank you.
ITunes
ITunes could not connect to the iTunes Store. An unknown error occurred (0x80090318).
Make sure your network connection is active and try again.
OK
Read more
Hi Brainy,
When I try to run the application which is built in Visual Studio 2005 with Crystal Report bundled version, I ended up with this error message. It works fine in local but the problem triggered when I put this in server. I searched via google and found some solutions like creating a bin folder and copying dll files there. Where do I find these dll files? Please help to fix this error. Thanks.
Error :
Unhandled exception has occured in a component in your application. If you click Continue, the application will ignore this error and...
Read more
Hai,
I am struggling with this unknown error, not able to find the cause of this error message. For your information the operating system is Windows 8 64 bit and 1 GB RAM. And of course it’s an Intel processor, then why I am getting this error? I googled this error and checked the drivers and BIOS are they are updated. Please help.
Error :
Intel Hardware Accelerated Execution Manager Setup
Failed to configure driver: unknown error.Failed to open driver.
Read more
Hello Whiz,
I successfully installed the iSM software from NEC without any issue, the problem appeared when I hit the settings in configuration button. Is this a problem with the Windows compatibility? Do I need to change any system settings? Please help me to rid of this problem and guide me. Thanks in advance.
Error:
iSM
[25222]
The client under composition setup already exists.
Read more
Hello Friends,
When I am trying to install XMOS/Thesycon, I ended with an error message. I have tried this installation Windows 7 and Windows XP, works well and good without any issues. But when I try in Windows 8 I am getting this error message. XMOS cannot in Windows 8? Please help me to get installed in windows 8 operating system. Thanks.
Error :
Setup
Preinstallation failed! Please run setup again. If you are asked to confirm installation of software, please confirm.
Read more
Hai DBA’s,
When I try to install the Oracle Database 11g in my system, I stuck up with the error message. Installation was not even half way, it failed to go further. I have window XP operating system 64 bit, 1 TB Hard drive. When I hit the continue button, getting lot of error subsequently not able to login. Any files corrupted during installation? Re-installation also seems to get the same error. Help me to solve this problem. Thanks.
Error:
File not found
C:apporcaleproduct11.2.0dbhome_1owbexternaloc4j_applicationsapplicationsWFMLSRVCApp.ear.
Read more
Hi –Ya,
When I try to install the gSyncit, ended up with this error 2503. Googled and find out that Windows user Access control setting is blocking the gSyncit install. How do I lower the UAC setting? Help me. Then help me to find the registration key EnableLUA property to 0. Struggling with this error, please help me to resolve this error. Thanks.
Error:
The installer has encountered an unexpected error installing this package. This may indicate a problem with this package. The error code is 2503.
Read more
Hi Brainy,
When I attempt to install the Microsoft Communications Managed API 4.0 on a Windows Server 2012, I ended up with this error message. Is this requires any specific system requirements before installation? Am I missing anything? I am doing this in Windows server 2012, think this is supported. Help me to fix the error. Thanks for your help.
Error :
Setup has detected that this computer does not meet the requirements to install this software. The following blocking issue must be resolved before you can install Microsoft Unified Communications Managed API 4.0, Runtime software package.
Installation Requirements:
Microsoft...
Read more
Hi all,
I got this error message when I try to install the Foxit Reader. An error stating that I don’t have permission to view this object’s security properties. The system is not connected in the network and also tried as an administrative user even this triggered me this error again. For you information I am getting this error for all installation which I did recently. Do I need to make any change in system security settings? Help please.
Error :
C:Program Files (x86)Foxit Software>takeown /Foxit Reader
ERROR: Access is denied.
You do not have permission to view this object’s...
Read more
Hello Expert friends,
Friends I never used Pro Tools HD 10 before this is the first time. I was a bit curious while installing, but it failed to launch. Don’t understand where I went wrong, struggling to find the cause of error. I tried deleting the temporally created DAE files and emptying the trash and temp files, but no luck. Thinking that anti-virus might prevent in installation, so disabled the anti-virus and tried again nothing worked. Please help. Your help is appreciated.
Error :
Could not allocate memory for the disk cache. Try lowering your disc buffer (DAE...
Read more
