Archive
Hi Everyone,
I am facing a problem trying to get After Effects CS3 to work. I could download and install the application without any issues. Then I tried launching the application. After Effects launches a displays the splash screen but soon afterwards an error message is displayed and the application crashes. I tried installing After Effects on a Windows XP SP2 machine as well as Vista ultimate SP1 machine. But this software does not work on either of the machines. The error message suggested that I look for a solution at the Adobe support website. But I was...
Read moreHello Pals,
I recently installed the 3DS Max 2011 on my machine and it gives me a very trying time attempting to startup. As soon as I launch it I get an error message displayed reporting a missing procedure entry point in the splash.dll. The error message doesn’t offer you any other choice than click ‘OK’. Now comes the most irritating part click ok and immediately the error message reappears. Click ok again and there it is back. Now if you are still game you can stop counting and keep clicking. Anyway after a while your perseverance is rewarded. The...
Read moreHello,
I am using Photoshop CS6 with Windows 7, 64 bit on my laptop. I am attempting to use actions that require an image to be opened, selected, copied and closed and then this image in the clipboard must be pasted on to another Photoshop image that is already opened. I had whole of this action working perfectly in Photoshop CS5 but coming to CS6, I get this error saying ‘Command paste is not available’. I tried out the same 8-bit images in CS6 that I used in CS5 and still this does not work. What is going wrong in...
Read moreHello Everyone,
I am hoping to find someone who can tell me how to obtain a license for Maya 2011 trial version. I have been trying out all possible methods for the last two days and do not seem to have luck with any of them. I have tried installing this software on my windows 7 laptop several times now and always end up getting this license not obtained error when trying to run Maya. I searched for a solution and tried deleting the ADLM folder from the C:ProgramDataAutoDeskADLM and restarted my machine and tried running again. But this method...
Read moreHello All,
I am getting an error on startup of After Effects CS4. I get a crash in progress message as soon as I try to open this application. I have tried uninstalling and reinstalling the software a couple of times. But I soon gave it up as a futile attempt. Then I tried restoring default preference settings on my windows XP machine by holding CTRL+ALT+SHIFT. But this method didn’t help me either. I had OpenGL rendering turned on and I tried to turn it off to see if this makes any difference. But this only resulted in another failed...
Read moreHi Everyone,
I recently installed AutoCAD 2010 on my computer and am quite happy this application. However, when I try to plot a drawing I always come across this error message informing me that this task could not be performed as there are no output devices configured. I attempted to plot the drawing by clicking the plot icon and I get this error message every time I do this. Next, I tried adding a Plotter Wizard by going to plotter manager and choosing Add a Plotter Wizard option. Again I attempt plotting a drawing and am still not able to...
Read moreHi All,
I am trying to get Photoshop working on my Ubuntu machine and so far have not been very successful. I installed the application from application from a wine-doors install and had it installed perfectly without any trouble. And I tried launching it and that worked fine too and Photoshop opened. I closed the application after just testing some features and did not save any work. However, today when I try to open Photoshop, I get an unable to continue error message. An application that working perfectly suddenly finds an unrecoverable error today!!! I have not the faintest idea...
I am using 3DS Max 2010 on 64 bit windows vista machine and everything was working fine until I installed the hot fix 2010-2009.09.22 on my machine. Now when I launch 3DS Max, I get an error message stating an error loading some of the DLLs. I get about 5 such messages and then 3DS Max starts up. I thought may be the hot fix was not installed properly and tried to undo it and tried installing again. But I did not get it to work that way. Is this a bug in the hot fix? Did anyone...
Read moreHi Experts,
I hope someone can help me with this error I am getting when exporting meshes out of Maya. I created the model of a sofa in Zbrush and exported it as an obj in Maya. I need to get this mesh exported from Maya 2009 to Unreal 2004. I activated the static mesh exporter by typing ‘axmesh’ at the command prompt. And Maya triangulates the mesh preparing to export the model, but soon afterwards I get this fatal error. I tried exporting several times but I am not able to find what is causing this error. I suppose...
I recently purchased a license for CorelDraw X5 Student and Home edition being impressed with the many services provided by this applications through a couple of versions up to CorelDraw 12 . I installed this software successfully too. But I encounter a problem when I attempt to set the PhotoPaint as the default program for JPG, BMP and GIF file types using the Windows 7 default program changing app. As soon as I attempt this, I get an error message stating that the Visual Basic for Applications could not be initialized and that it must be reinstalled. I...
Read more
