Archive
Hello Everyone , I have added my daughter to my computer and I tried to set up her account. After a lot of tries I always get an error message from Windows Live Family Safety. I was struggling a lot to deal with this error, because at first I did not know how to fix it. I tried checking the registry, compared the settings on different computers, downloaded New SID utility tool for my windows. I have also tried to reset and enable my computer accounts .All of those methods failed. After a lot of researching I found out...
Read moreHi,
This morning this error appeared when I was trying to to run my game Borderlands 2. I don’t know what happened since last night worked just fine. I don’t want to reinstall the game because it takes a lot of time and I will lose all the savings in game. Can anyone help me to repair my game and please explain me what I did wrong ?
Thanks !
Message
I/O failure operating on
..WillowGameCookedPCConsoIePandoraPark_P.upk
RaiseExceptionO Address = 0x74e19673 (filename not found) [in
CWindowssystem32KERNELBASE.dll]
GetOutermostO Address = 0x1823cd3 (filename not found) [in
J:SteamsteamappscommonBorderlands 2BinariesWin32Borderlands2.exej
GetStackOwnerClassQ Address = Oxl6fZfl2 (filename not found) [in
JSteamsteamappscommonBorderlands 2BinariesWin32Borderlands2.exe]
AK:Monitor.:PostCodeO Address...
Read moreHi there,
I have installed Rome: Total War 1 month ago and it worked just fine until today when I have opened my PC. Last time when I played I made some changes in settings and saved some mission and closed the game with Alt+F4. I have this error message and I can’t run the game. Please someone help me to repair my game and tell me why is not working anymore ? How can I fix this and avoid any errors in the future with this game ?
Thank you !
Rome: Total War - Barbarian Invasion
Generic...
Read moreHi,
I have installed SegSvr 32 to install and register some DLL file on my Windows XP (X32) and when I want to run it this error message prompter on my desktop. I tried to reinstall the program, but this error continues to appear. Please help me to install this properly and tell why I can’t install the DLL files without getting any error.
Thanks !
RegSvr32
C: WINNTsystem32xvidcore.dll was loaded, but the DllRegisterServer entry point was not Found.
DllRegisterServer may not be exported, or a corrupt version of C:WINNTsystem32xvidcore.dll may be in memory. Consider using PView to detect...
Read moreHi there,
I am using a FXC.exe utility from the Direct X SDK to load some shaders for a game. After I did that this big error appeared and blocked me. I don’t know anything about what it is said here. Can anyone enlighten me about this error and what it means ? How can I fix this and how to avoid it in the future ?
Thank you !
Message
Diect3DDevice -> CreatePixelShader(DWORD*)&Code(0),(lDirect3DPixelShader9**)PixelShader.GetlnitReference() failed at R:WILLOW2-PCORCHIDTULIPDevelopmentSrcD3D9DrvSrcD3D9Shaders.cpp:20
with error 88760028
RaiseException() Address = 0x7c81 2aFb (Filename not Found) [in C:WINDOWSsystem32kernel32.dIl]
AK:: SoundEngine::StartOutputCapture() Address = Oxl 161 b63 (Filename not Found) un C:Program...
Read moreI want to ask a query regarding my Enterprise Vault installation. I installed it successfully but when I launched it, an error appears. I installed it on my Windows XP PC and I can't make it run. How can I be able to resolve this? The error message is posted below:
Enterprise Vault Installation Error
Error registering file: C:Program Files (x86)Enterprise VaultAdminService.exe
Display Log Finish
Read moreHi experts,
I have bought a game controller for my laptop and I have some problems in installing it. I have plugged in the device, and during the installation of the driver it stopped with this error. Is a new controller and is compatible with my Windows 7 (x32) and I need someone to help me to fix this and install it properly.
Thank you !
SideWinder Game Controller Software 4.0
There was an internal error that may be due to low system resources. Please close this program. as well as other open programs, and try again. If the...
Read moreHello,
I have created a WPF file on my computer and is running ok on my Windows 7, but when I want to deploy I have this error with Content Load. I have loaded the WPF file and tried to deploy it again. Can’t do it and the same error appears again. Does anyone have any idea how can I fix this ? What is wrong with this ?
Thanks !
Content Load Error
System.Windows.Markup.XamlParseException loading C:Program Files (6)Steamsteamappscommonsid meiers civilization v sdkModBuddyStartPageStartPage.xaml’:
Cannot create unknown type {clr-namespace:ModBuddy.StartPageassembly=ModBuddy.StartPage, Version=1.O.O.O, Culture neutral, PublicKeyToken=33fbf2a429992735)FixedMruListbox. Line number ‘131 and line position ‘26.
Read moreHello there,
When I want to play any game it crashes at the startup and this big window error appears and it is saying something about delta time, no idea what it means. All my games worked fine last week until now with this error. I don’t know that it means and how to solve it. Can anyone tell me what is happening with my games ?
Thanks !
Message
Detected negative delta time - on AMD systems please install http://files.aoaforums.com
RaiseExceptionO Address = Ox76efc4lf (filename not found) [in
C:Windowssyswow64KERNELBASE.dll]
Address = 0x15213c3 (filename not found) [in C:Program Files
(6)SteamsteamappscommonBorderlands
AK::SoundEngine:StopOutputCaptureQ Address = 0x19f35d2...
Read moreI am having problems on mounting my NTFS formatted drive on my MaC PC. But after upgrading to OS X Lion, I can no longer mount my drives. It works well before but after the recent upgrade, I was unable to. The Disk Utility can read my formatted driveS but it won't let me mount them. I am using MacBook Air with Nvidia GeForce 320M running Mac OS X Lion 10.7. How can I fix this?
NTFS-3G
NTFS-3G could not mount /dev/disk1s1 at /Volumes/LaCie because the following problem occurred:
Did not receive a signal within 15.000000...
Read more
