Archive
Hi there,
I have a Microsoft Excel file from college and I am unable to open it on my MAC. To all my colleagues works fine, but on my MAC I have this error message. If I click Open as Read-Only button the file shows like is empty. I need this file for a project so can anyone please help me to fix this ? Why I am the only one that can’t open this file ? I will have problems with another excel file in the future ?
Thanks !
Excel cannot open this file.
The file format...
Read moreHi there,
I have installed the Microsoft Train Simulator game and I when I was trying to play it this error stopped me. I have installed on my PC other simulation games and never had a problem with them. I have reinstalled the game, copied and did everything that was required and I couldn’t get rid of the error. Can anyone help me to fix this and help me to play this game ? Why is this the only simulator game that gives me an error and the other don’t ?
Thanks !
Failed to initialize...
Read moreHi there,
I tried to install Steam today, but during the install I got this error message box and it blurred me totally. I have tried also, to install a lot version, but this error appears to all. Recently I have made some updates to my Windows 7 (x32). Can anyone tell me if the updates are the problem with my steam and that’s why I can’t install it ?
Thanks !
Steam.exe - Entry Point Not Found
The procedure entry point _RIB_alloc_provider_handle@4 could not be located in the dynamic link library mss32.dll.
OK
Read moreHi there,
I have an error with the Microsoft Train Simulator game and I when I was trying to play it stopped me. I have reinstalled the game, I did everything that was required and I couldn’t get rid of the error. Can anyone help me to fix this and help me to play this game ? Why is this the only simulator game that gives me an error and the other don’t ?
Thanks !
Error: continue?
Failed to open texture File
routesAU_NSW_Ni2texturesacleantrack1.ace
Yes
Read moreHi,
Today this error appeared when I was trying to to run my game Borderlands 2. I don’t know what happened since yesterday worked just fine. I don’t want to reinstall the game because it takes a lot of time. Can anyone help me to repair my game and please explain me what I did wrong ?
Thanks !
Message
Fatal error!
Address = 0xa388bc (filename not found) [in C:Program Files
(6)SteamsteamappscommonBorderlands
2BinariesWin32Borderlands2.exe]
Address = OxbObOdd (filename not found) [in C:Program Files
(x86)SteamsteamappscommonBorderlands
Address = 0x121299f (filename not found) [in C:Program Files
2BinariesWin32Borderlands2.exej
Address = 0x62e62c (filename not found) [in C:Program Files
Address = Oxl4bee8l (filename not found)...
Read moreHi,
Thanks !
Message I
SECURE CRT: Invalid parameter detected.
RaiseExceptionO Address = 0x7594b9bc (filename not found) [in C:Windowssyswow64KERNELBASE.dIl]
CxxThrowExceptionO Address = OxfO5df6O (filename not found) [in C:WindowsWinSxSx86_microsoft.vc9O.crt_lfc8b3b9al el8e3b_9.O.30729.6161_no ne_50934f2ebcb7eb57MSVCR9O.dfl]
GetOutermostO Address = Ox5ecaf8 (filename not found) [in d:steamsteamappscommonborderlandsBinariesBorderlands.exe]
Glmage::Glmageo Address = Ox5c43dd (filename not found) [in...
Read moreHi there,
Today when I opened my laptop this error message appeared on my desktop and everything froze. I had no icons on desktop, no taskbar, nothing, only my keyboard worked. I waited for 15min and could click OK and everything worked fine. I have no idea what this means and what happened. Can anyone help me tell why I had this error ? How can I prevent this to happen again ?
Kind Regards !
System.IO.IOException: The semaphore timeout period has expired.
at System.IO._Error.WinIOError(1nt32 errorCode, String maybeFullPath) at System.IO.Pipes.NamedPipeClientStream.Connect(Int32 timeout) at Dotjosh.DayZCommander.App.SinglelnstanceHandler.RelayToServero at Dotjosh.DayZCommander.App.SinglelnstanceHandler..ctorO
OK
Read moreHi,
Today I was playing a game in steam mode and everything worked fine without any error.This evening I wanted to play but it seems like my steam is down. I don’t know what happened with my steam, I didn’t make any changes. I don’t know how to fix and I don’t want to break it more than it is at this moment, so can anyone help me to fix this and tell me why I have this error today ?
Thanks !
Steam failed to load: *SteamStartEngine(0x43f6c0) failed with error 1:
Cannot open blob archive file: CMultiFieldBlob(mem-mapped file):
Failed...
Read moreHi there,
When I want to make an update to my Workshop from Creation Kit I got this error when I want to upload them. It doesn’t what I did wrong, it is a failure to write the mod file. Is for the first time when I have this kind of errors and I am a little bit surprised and got stuck with it. Does anyone know how to fix this ? What is wrong and why I never had any problem to make some updates ?
Thanks !
Failed to write the mod file to the cloud
Read moreHello there,
I play all my games that I have installed with Steam, never had any problems until this evening. When I have tried to run a game this error message appeared. I changed the game same problem, I can’t run any game on my PC without getting this error. Does anyone else have this error ? How this error can be fixed ?
Thank you !
Engine Error
Internal driver error at Present.
You’re likely out of OS Paged Pool Memory! For more info, see
https://help.steampowered.com/en/
OK
Read more
