Archive
The installation of SoftPerfect Network Scanner was successful without throwing any error. Now all of a sudden I am getting an error message. The error message says that it could not get the interfaces list. I am not a technical person so having hard time with the error. How I can solve this error? Please help. Thanks in advance.
Errors:
Could not get the interfaces list. (System Error. Code: 126. Das angegebene Modul wurde nicht gefunden)
Read moreHi Tech folks,
I am getting a weird incomplete error message when I open Internet Explorer. I am not a technical person so finding very difficult to handle this situation. What I have to do now to stop this error? I tried to repair it but nothing works, do I need to reinstall? Please help to resolve this error.
Internet Explorer Script Error
An error has occurred in the script on this page
Line:
Error:
Code:
URL:
Do you want to continue running scripts on this page?
Yes No
Read moreHello Troubleshooter,
Android Studio installation was successful without any error. The problem triggered when I try to launch the application I ended up with an error message. After a search, I even updated the IDE but no result still I get the following error message. Please help me to resolve the error. Thank you.
Invalid Config Path
Config path “C:Program Files (x86)Androidandroid-studioconfig” is invalid.
If you have modified the ‘idea.config.path’ property please make sure it is correct, otherwise please re-install the IDE.
OK
Read moreHi there,
I got this weird error message when I am working in Adobe Lightroom. I do not have much knowledge about Lightroom. I am not getting the error message correctly. Is that says a document is empty? I have been working in the document for a week. What might be the root of this error? Please support to find the solutions. Thanks.
Can’t update this collection.
An internal error has occurred: Error
Domain— NSXMLParserErrorDomain Code=4 Line 1:
Document is empty
Userlnfo—0x11201f850
{NSLocalizedDescription = Line 1: Document is empty
OK
Read moreHello experts,
I have Windows 7 64-bit operating system with 8 GB Ram and 250GB hard disk. I install Android Studio latest version and Java SDK in the system it was successful without any error. I got an error message when I try to launch the Android Studio for the first time. I do not have any idea why it is happening. Please help me to fix the missing dll file in the computer. Thanks.
Error launching Android Studio
Failed to load JVM DLL C:Program FilesJavajdk1.7.0_25jre.
If you already have a 32-bit JDK installed, define a JAVA_HOME variable in
Computer>System...
Read moreHello all,
I am newcomer having hard time with these codes. I got an error message when I try to run the code. The error message states that ‘Syntax error EOL wile scanning single-quoted string’. I have the error image for more information. Please explain me in detail to fix the error. Your help is great. Thanks a lot.
Syntax Error
EOL while scanning single—quoted string
File: “Untitled Script 2”, line 2
print “Here are the ten numbers from 0 to 9
Cancel Edit
Read moreHi experts. I'm having troubles installing resynthesizer plug-in. Every time I try to run it, the screen pops out with an error. As you can see in the image below, the error says that intl.dll was not found. I have not touched the installation folder. If someone knows how to solve this, please help me. I will be very grateful
Resynthesizer.exe - Unable To Locate Component
This application has failed to start because intl.dll was not found. Re-installing the application may fix this problem.
Read moreHi there,
Friends I have a Gmail account and I have downloaded the Picasa from the official website. When I try to upload an album, I was stuck up with an error message. I even tried to upload a single photo but I get the same error. Please help me to resolve this error. Thanks a lot.
Error
This account is not enabled for Google Photos.
Would you like to open a web page that may help resolve the problem?
Yes No
Read moreHello tech experts,
I did not have any problem or issue while installing Abode Illustrator. Now I am facing errors day by day. Today when I open the existing file or when I try to create a new one I ended up with an error message. The error message states that there is not enough memory to open the illustration. How I can solve this error? Please help me. Thanks in advance.
Adobe Illustrator error
Not enough memory to open the illustration.
Read moreHey friends,
When I try to update the Picasa online, I was stuck up with an error message. I tried it again after some time but I got the same error. I check the antivirus it is not blocking the update. Very confused, I am not a technical person. How I can update it without an error? Please help. Thank you.
Update Error.
Picasa was unable to check for updates. Please try again later.
Read more
