Archive
Hi experts,
I downloaded Pidgin version for Windows and when I open the installer this error message box appeared on my desktop. I downloaded from different servers and still the same error. After I read the error I looked for the DLL file that is missing and no result. This software works just fine on my friends PCs and I am the only one with problems. Please help me to install this properly and if is a problem with the installer please give a link for download.
Thank you very much!
pidgin.exe - Entry Point Not...
Read moreHello there,
I tried to install Windows 2000 to an older PC that I have for back-up and this error stopped the installation. I tried to install it from a CD and a USB and both have this error. For the moment I don’t think that might be an error with Windows 2000 because I used before and worked just fine. Please can anyone help me to fix this and also tell me why I have this error?
Thank you!
Isass.exe - System Error
Security Accounts Manager initialization failed because of the following error: The security ID...
Read moreHi there,
I tried to update my .NET Framework and after downloading when I ran the install package this error appeared. I didn’t find this DLL file to download it and I get stuck with this error. Does anyone have any idea how can I fix this? Please tell what this error means and how can I avoid it in the future?
Thank you!
Assembly Cache Viewer -Install failed
Access is denied: WebPartstepBiStep.dII.
OK
Read moreHello,
After I made an update to my Windows Vista this error message boxes appeared on my desktop. I don’t know if I can roll back the updates and if this is possible. I never experienced such an error before and I am stuck with this. Can anyone please tell me how can I fix this without reinstalling my Windows Vista? Should I make updates when they are available?
Thank you!
Exception Processing Message 0xc0000139 Parameters
0x000007FCD2217438 0x000007FCD2217438 0x00000000C0000139
0x000007FCD2217438
OK
The procedure entry point CoCreateinstance could not be located in
the dynamic link library B:WindowsSYSTEM32DSOUND.DLL.
OK
Read moreHello,
I want to install some new apps on my phone, but every time this error stops me. I don’t know how can I fix this and I reinstalled everything. Is for the first time when I have this error and I am a little bit confused because I don’t know if a problem with my phone or my laptop is. Can anyone tell me how can I fix this? Why I have this error now?
Thank you!
Something happened and this app couldn’t be installed. Please try again Error code:
0x80080008
Try again Cancel Install
Read more
Hello experts,
I have this error with Graal 4 when I want to install it. I have downloaded it at least 5 times from different servers but I have the same error when I want to install it. I don’t know what to do anymore so please is there anyone who can help me to fix this? Is there a problem with my PC or the installer is broken?
Thank you!
Executable ‘C:Documents and SettingsBryanMy DocumentsGraal4Setup.exe’ had the following unrecoverable error:
Library C:Progra~1MICROS~2Office12GRA8E1~1.DLL is linked to missing function
MSVCR80.dll:?_type_info_dtor_internal_method@type_infor@QAEXXZ
Read more
Today when I opened Autodesk it work fine for a while, but suddenly this error message appeared and after I pressed OK it closed my project and software and lost everything. Is there any way to solve this and maybe I can get back my work? Please help!
Thanks!
Revit could not load D:AUTODESKREVIT STRUCTURE 2012PROGRAMCONCEPTUALENERGYANALYSISDB.dll
Read moreHi there,
I uninstalled a program and after I reboot my PC this RunDLL error appeared. This error appears every time I open my PC. After some searches on the Internet I didn’t find anything. I would like to know if I install the program again this error will disappear. How can I fix?
Thank you!
RunDLL
Error loading C:UsersAdmin1AppDataLocalTempubielbpl.dll The specified module could not be found.
OK
Read moreHello,
I have this error with license for Adobe. I can’t activate it and I don’t know why. It is my first software with a license so I am newbie with this. I contacted the Adobe support but no answer. Can anyone help me to fix this? Please tell me the steps to activate my software.
Thank you!
WinLicense
Cannot find curllib.dll. Please re-install this application
OK
Read moreHi,
This morning when I opened my PC this error popped-up. I made some search but I found nothing, I tried to search for the missing DLL file but nothing found. The problem is that I have this error every time I open my PC. Can anyone please tell me how can I fix this? Why I have this error?
Thanks!
I1Profiler.exe - Entry Point Not Found
The procedure entry point kXRDeviceCommandBeginCalibrate could not be located in the dynamic link library XRiteDevice.dll.
OK
Read more
