Archive
Today I made an update to my Windows XP (X832) and when I try to open my printer this error message box appears. Also I made the updates to my printer drivers and nothing is happening. Does anyone in here can help me with my error please?
Thank you!
HP Connection Manager Service has stopped responding. Please exit and restart the application.
A fatal error occurred, check the HP Connection Manager in Event Viewer for more details.
Retrieving the COM class factory for component with CLSID { 24D646C0-C042-4E9 1-9AC4-0A9525A555 1D} failed due to the following error: 80070422,
OK
Read more
My Windows Updater told me that it will be good if I make all the updates that were required. I did so, and after rebooting this application error appeared. I never had this error before the updates and this is the 1st time when I have it. I want a PC without errors and please can anyone of you experts help me fixing this error? Can this be solved without reinstalling my Windows?
Thank you!
Werfault.exe - Application Error
The instruction at 0x7d235e25 referenced memory at 0x00760065. The memory could not be written.
Click on OK to terminate the program
OK
Read more
I have this error message with my Kaching mobile banking. I used this app on first android device and it worked great. Now I have an Apple device and this error doesn’t let me to make some payments. Does anyone have any idea why this app is not working on my Apple device ? Is there a solution for this or should I change the device ?
Thank you !
Security notice
Sorry, CommBankKaching is unable to be supported on this device.
OK
Read more
Hi experts,
A long time passed since I was not scanning anything with my printer and today I wanted to scan some documents this error message appears unexpectedly on my desktop. I did everything that error said without any result. Can anyone help me to fix this error? How can I restore my scanner?
Thanks!
Scanner Unreachable
Scanner communication cannot be established. Ensure your product is powered on, check the connection, and ensure your network is functioning properly. If these conditions are correct, restart the product and try scanning again.
you installed this printer by IP address, then you might need...
Read more
Hi there,
Today I made an update to my Windows 7 (x86) and when I try to open my printer this error message box appears. Also I made the updates to my printer drivers and nothing is happening. Does anyone in here can help me with my error please? Is this because I made the updates to Windows?
Thank you!
Selected printer driver not found
The specified location does not contain the driver HP LaserJet 1160 for the requested processor architecture
Retry Cancel
Read more
I want to play FIFA 14 on my iPad with origin but I have this error. My Internet connection is working perfect. I can surf on the Interned on iPad and this is the only error that I have when I want to use the Internet. Can anyone tell me why the Origin is not available ? Is there a problem with my Internet or the game ?
Thank you !
ERROR
Origin is not available.
Please try again later or check your Internet connection.
OK
Read more
I have this error when I try to send an email. Is not working at all, it doesn’t matter if I use my wireless connection, 3G or anything else. I made all the necessary updates and nothing solved my error. Can anyone help me to fix this error ? What happening with my phone ?
Thank you experts !
Cannot Send Mail
An error occurred while delivering this message.
OK
Read more
Hi there,
This message appears every time I want to play Pro Evolution Soccer 2010. It says that my PC is not good enough for this game, but FIFA 10 and any other games are working just fine. This is the only game that gives me this kind of error. If I click Ignore this error appears again, if I click Retry again. Is there a solution for this? My VGA have 512MB and is not working. Thank you!
Warning:
Your computer does not meet the minimum specifications necessary to run this software.
You may experience...
Read more
I have this error on my iPad every time I open my Internet browser and try to surf over the Internet. Sometimes is working for a while and sometimes is not working at all. I tried to run different browsers but none was working and solved this error. Does anyone have any idea about this ? What is the error ?
Thanks !
Oops! Sorry, it looks like something went wrong and an error has occurred. Please refresh your browser to restart the application.
Read more
For a while it seems like I have some DLL file errors. For two days it started to appear on my windows startup and is. Nothing happens when I OK them but still. Can anyone help me please to fix these errors ? Why I have this errors and should I reinstall my Windows ?
Thanks !
SSF.exe – System Error
The program can’t start because d3dx9_43.dll is missing from your computer. Try reinstalling the program to fix this problem
OK
Read more
