Archive
Recently I made some changes in my Windows hoping my PC will run easily and I will get better performances. It worked fine for two days when this morning I got this error. Can anyone help me to fix this please without reinstalling my Windows? Can this be solved without losing any data?
Thank you!
Time Left: 0:07
A problem was encountered when opening the flies for this DVR event.
Please note the Error Code: 06
Read moreHello experts,
A friend of mine recommended to install BlueStacks App because I can have access to many apps for my devices. While installing the software I have this error. I don’t know what this error means and why I have it since most of my friends are using it? Does anyone can help me to fix it?
Thanks!
BlueStacks App Player lnstall Wizard
BlueStacks currently doesn’t recognize your graphics card.
It is possible that your graphics Drivers may need to be updated. Please update them and try installing again.
Read more
Today I made some updates to my Windows 7 and my sound card stopped to work. I tried to reinstall it and the install was stopped because of this error. Can anyone help me to fix this error? How can I prevent this error to happen again when I will make new updates?
Thanks!
Warning: This model is not supported. SRS audio enhancement may not operate correctly for this device. The default settings will be installed.
OK
Read moreHi there,
I have this error in Microsoft System Center 2012 when I want to create a protection group. I watched some tutorials on the Internet to learn how to use this but sometimes I am stuck with days with an error. Please, can anyone help me to fix this error? Is there an article on this website about Microsoft System Center 2012?
Thank you!
Microsoft System Center 2012 Data Protection Manager
Eseutil consistency check cannot be performed for this protection group, as eseutil .exe is not present on the DPM server
Copy the following files from the...
Read moreHi,
I have this error caused by Microsoft Visual Studio and it seems like I still have missing DLL files from my PC, even I ran a DLL fixer. I tried to copy manually the missing DLL file on my system 32 and is not working. Please is there anyone that can help me with this error? How can I install all the possible DLL files?
Thanks!
RegSvr32
The module ‘C:WindowsSystem32IEShims.dIl’ was loaded but the entry-point DllRegisterServer was not found. Make sure that ‘C:WindowsSystem32IEShims.dll’ is a valid DLL or OCX file and then try again.
OK
Read more
After I have installed a new printer on my laptop I have this kind of error when I want to print a file, any file. Is my first printer and I don’t have any experience in managing the printer errors, especially solving them? Can anyone help me to fix this? Why I have this error and how can I prevent this to happen again?
Thanks!
Some of the software for the printer is missing.
The software for the printer was installed incorrectly. Please reinstall the software from the manufacturer.
Cancel
Read moreHi there,
I have difficulties when I want to install some softwares. This is one of them. I don’t have any solution for this. Can anyone help me to fix this kind of errors? What can be the main cause of this error and how can I prevent this to happen again?
Thank you!
ieuser.exe - Bad Image
C:Windowssystem32MSHTML.dll is either not designed to run on
Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or the software vendor for support.
OK
Read moreHello,
I updated my Dolby Home Theater v4 and while installing this error message box stopped the installing. When I click OK on the error all actions are rolling back and if I try to install it again the same error appears. Can anyone help me to install the updates to my PC? Is something wrong with the driver’s updates?
Thank you!
Could not open key:
HKEY_LOCAL_MACHINESOFTWAREDolbyPCEE4AppKeys. Verify that you have sufficient access to that key, or contact your support personnel.
OK
Read moreHello,
Restarting my PC is not helping to solve this error. Nothing that I can do and I know works. After I updated my Windows I can’t install some of my drivers. What is the best solution for this kind of errors? How can I solve this one so I can listen some music?
Thank you!
Configuring SigmaTel Audio Driver and Applications
ExitError:Error= Device Object not present restart the system and run setup again
OK
Read more
I just download and installed Emdat app from App Store and the application is not responding and I have this error message. A friend of mine recommended this app and I would like to use it properly. Does anyone have any idea about this app error ? How can this be solved ?
Thank you experts !
Sorry!
Activity Emdat Mobile (in application EMdat Mobile) is not responding
Force close
Wait
Report
Read more
