Archive
I have this error with Windows Store Apps when I try to create a profile. I am a beginner with the PC and every time I have an error I am scared because I don’t want to ruin my PC. This is one of them and can anyone have some free time to help me fixing this error?
Thanks!
NP .NET Profiler for Windows Store Apps
Please copy NPProfiler.dll to the below folder C:NPx86NPProfiler.dll
OK
Read more
Hello experts,
My new game Prototype 2 Engine have this error and sadly I can’t play it. I’ve been waiting a long time for this game to appear and now I am disappointed. Can you experts help me to play the game without any error and any problem? If I install some new games I will have the same error?
Thanks!
Main Win32
ERROR: Could not load DLL ‘prototype2engine.dll’. You probably have a static initializer that is crashing.
The most common cause is forgetting
core: :Name5tringAllocationstatic in a static core: :Name:
static const engine: Name Foo( “Bar”,
core:: NameStringAllocationStatic);
Or verily that...
Read more
My new antivirus Kaspersky offered me tonight this error when I opened my PC and the program closed when I pressed OK. I have this one for 2 days and worked OK, exception this error. Can anyone help me to fix this error? IS there an error with Kaspersky?
Thank you!
KAV Script Checker
Cannot load library For language ‘JScript’
Path: ‘C:WINDOWSsystem32jscript.dll’
Please contact Kaspersky Lab For the solution, (err=00000005)
OK
Read more
We are working on an OPC Project and have .Net Assemlys in dlls from a vendor. The vendor provides 3 assembly dlls for .Net 1.1, 2.0 and 3.5. When I try to browse to a constructor on the .Net 2.0 dll I get an an error "The selected file is not a .NET assembly, type library or automation executable."
Thank you!
OK
Read more
Hello there,
I have this error with this software, I want to find out if there is a problem with my laptop. Please experts help us to fix this and maybe you can tell what and why this error appeared.
Thank you!
RegSvr32
The module “C:HTMLtoolshtmlshell.dll” was loaded but the
call to DllRegisterServer failed with error code 0x80020009.
For more information about this problem, search online using the error code as a search term.
Read more
Hi there,
This morning Microsoft Outlook showed up this error message box. Is for the first time when I have this kind of error, actually I never had errors with Outlook. I tried to reinstall and is not working. Please is there a solution for this error? How can this be solved?
Thank you!
Microsoft Outlook
The add-in “C:WINNTSystem32ActExt.dll” could not be installed or loaded. This problem may be resolved by using Detect and Repair on the Help menu. Unable to load C:WINNTSystem32ActExt.dll. You may be out of memory, out of system resources, or missing a dll...
Read more
Hi experts,
I have this error when PC is loading. I click Restart and the system starts to restart. This error doesn’t appear every time I open my PC but is really annoying because I can’t use my PC all day sometimes. Please can anyone help me to fix this error? What is the cause?
Thanks!
User Interface Failure
The Logon User Interface DLL NWGINA.DLL
Failed to load.
Contact your system administrator to replace the
DLL. or restore the original DLL.
Restart
Read more
Hi there,
While my PC was opening this error appeared on my desktop. I verified all my startup programs and the folder is empty. I made a small search on the Internet and nothing useful was found about this error. Does anyone have any idea about this error? How can I solve this, please help me!
Thanks!
LightsOut Client
Error
Error reading From File: C:DOKUMEr~1ALLUSEr~1ANWEND~1fAF73Z4}FFLINE92F156AOAAOF66D4NLogdll. Verily that the File exists and that you can access it.
Read more
When I turn on my PC and everything is loaded this error appears without any reason. The thing is that I tried to make an update to my Windows XP but my PC turned off during the install. I start to think that this might be the problem. Anyone have any idea why I have this error? How can this be solved?
Thanks!
Windows Setup
Setup library wbemupgd.dll could not be loaded, or Function OcEntry could not be found.
Contact your system administrator. The specific error code is 0x7e.
Read more
I have an error with Counter-Strike when I want to play with Steam. After this error, and after I have waited for 10 minutes, my steam is still busy to handle my request. It worked fine until today, so is my first problem with it, I never heard about such an error. Please tell me what is with this error message? Why appeared right now and can be solved?
Thanks!
Unable to connect to the server. The server maybe temporarily unavailable.
Please try again later. (err:7 state:3)
OK
Read more
