Archive
Hi experts,
I made the transition from Windows XP to Windows 7, and I had a big surprise. Because of this error I can’t access my Local E. I am “lucky” Local F is working. Can anyone help me to fix this error? Why I have this error? I never had it on my Windows XP.
Thank you!
Location is not available
E: is not accessible.
Access is denied.
OK
Read more
I bought a new motherboard for my PC and I have this error. I tried almost everything I know, reset the BIOS and change the jumpers but nothing works. I read the manual and I found nothing about this error. Does anyone have any idea why this error appears? How can this one be fixed?
Thanks!
Please enter setup to recover BIOS settings. USB Device Over Current Status Detected!!
System Will Shut Down After 15 Seconds.
Read more
I have some books stored on the cloud and when I try to download them it says that the items are invalid. The thing is that my sister can download the same books from the same cloud, I am the only one who can’t. Please help me to solve this error. What could be the cause?
Thanks!
Invalid Item
This item is protected with DRM and cannot be read on your Kindle. Please remove the item from your device and download it again or purchase a copy from the Kindle Store.
Cancel
Read more
Hello experts,
After the 1st part of the game finished, this error appeared on the screen of my tablet. I tried to watch to a football game on my tablet and it worked just fine when suddenly this appeared. Since that game this error appears every time I try to connect. Does anyone have any idea what is this all about? Can this be fixed?
Thanks!
Carrier Network Supporting Audio Only. Video Resumes When Connectivity Improves.
Read more
Recently I replaced my laptop’s battery with a new one. On the battery box says that is a universal one. When I turned on my laptop this caution appeared on my desktop and it says is not compatible with my laptop. I tried to send back the battery because of this error but they said to me that I shouldn’t pay attention to it. I am worried, please can anyone help me to fix this error? Is possible that the battery is not compatible with my laptop?
Thanks experts!
Caution
The installed battery may not be...
Read more
Hi there,
It seems like I have exceeded my storage limits. The truth is I don’t even know how much space available I had or is even full. Can anyone help me to see my profile? Why the link showed below in the error doesn’t work?
Thank you!
Profile storage space
You’ve exceeded your Windows Roaming Profile Quota. Run: ECN HELP -> Clean My Profile. If this doesn’t reduce your profile enough, see KB article “Windows Roaming Profile” @
https://engineering.purdue.edu/ECN.
OK
Read more
Hi there,
I try to install the Configuration Manager 2012 console on a workstation with an existent Configuration Manager 2007 console you will have the following error message. I would like to have the both versions and I don’t know how to make it works. Can anyone help me to fix this error? Is possible to have two versions of System Center?
Thanks guys!
Input string was not in a correct format.
OK
Read more
Hi there,
I cannot configure VirtualBox again. First time I used it worked wonderful without any error. When I want to use it again this error message box appears on my desktop and I can’t configure it right. How can I configure VirtualBox again? Is there some standard steps for this?
Thank you!
Error
Unable to start the Genymotion virtual device.
VirtualBox can’t run the virtual device.
Try to run the virtual device directly from VirtualBox to check for issues.
Check the log files for more information. For this, refer to:
https://docs.genymotion.com/latest/Content/01_Get_Started/Installation.htm
OK
Read more
This is not one of my first errors when I want to install some softwares. This one is most recent and I really want to use my Pro Tool 11. Does anyone have any idea how can this error be solved? Is something wrong with my OS? Also I would like if you can to provide another link for download.
Thank you!
Could not create a new document because Assertion in “/Volumes/Development/ws. ProTools_10.3.8/Afturaports/DFW/MacBuild/.. /Views/UMenu.MacOS.mm’, line 1351
OK
Read more
I uninstalled a program and after I reboot my PC this RunDLL error appeared. This error appears every time I open my PC. After some searches on the Internet I didn’t find anything. I would like to know if I install the program again this error will disappear. How can I fix?
Thank you!
RunDLL
There was a problem starting C:Program Files (x86)ConduitCT3289847pluginsTBVerifier.dll
The specified module could not be found.
OK
Read more
