Archive
Hi there,
Every time I have this error when I want to connect to my Outlook account. This started to happen after I did the necessary updates for my Windows 7 and now I don’t know how to fix it. Can any expert help me please ? How can I prevent this error ?
Thanks !
Test Account Settings
Outlook is testing the account settings you entered.
Log onto incoming mail server (POP3): Your e-mail server rejected your user name. Verify your user name for this account in Account Settings. The server responded: -ERR Command is not valid in this...
Read moreHi there,
I am trying to install Threat Management Gateway 2010 Enterprise on a Windows 2008 R2 server and during the install I have this error. My Internet connection is working just fine and also my Windows is working very well. Any solution for this error ? What is causing this ?
Thank you !
Microsoft Forefront Threat Management Gateway
No network adapters could be identified. The wizard cannot continue.
OK
Read moreHi there,
What this error means and I have it when I want to install Autodesk Inventor 2014. I have this kind of errors when I want to install another programs. I think it might be cause because recently I made some updates to my Windows 7. Is this the cause ? How can I solve this kind of error ?
Thank you !
Error 1309. Error reading from file: C”AutodeskWIAutodesk Inventor 2014.2014x64inventorProgram FilesCommon Files (64-Bit)FolderAutodesk SharedAdLMR7RegisterToday.dll. Verify that the file exists and that you can access it.
Forsok igen Avbryt
Read moreHi there,
After a long work time on a project in AutoCAD this error messed up everything and I lost all. After I click OK my PC froze and I had to reset the PC. Now this error appears more often and I don’t have a solution for it. Can anyone help me please to fix this ? What is causing this ?
Thank you !
Unhandled Access Violation Reading 0x0000 Exception at eaf28ea0h.
A software problem has caused AutoCAD LT to close unexpectedly.
We apologize for the inconvenience. An error report has been generated. Please click Send Report...
Read moreHi there,
I have this compatibility issue when I want to open a drawing file created with an older version of AutoCAD. The program from the error-DWG TrueView is not working at all, or I didn’t use it properly. Can anyone help me please to fix this error ? How can I make the proper conversion that will work ?
Thank you !
Open Drawing – Incompatible Version
The drawing file could not be opened because it was created with a more recent version of AutoCAD
To convert this drawing file to an earlier file format, download DWG TrueView from...
Read moreHello,
I want to restore mailbox data from a recovery database in Exchange 2010 SP1 and this is the error that I got. I have followed all the steps from the Help file and it seems I cannot make it. Can anyone help me please to make a proper recovery ? What step did I miss ?
Thank you experts !
Recovery Status
Recovery failed for Exchange Mailbox Database EX2010-MBX1-DB01 because the overwrite flag is not set for Ex2010-MBX1-DB01 on EX2010-MBX1.vkernel.local. (ID 30174)
Read moreHello,
After the update that I’ve made to my Windows 7 this is the error that I have every time when I want to AutoCAD. Until now I didn’t find a solution for this and I don’t want to reinstall AutoCAD. So is there an expert online that can help me please to fix this ? I have this error because of the update ?
Thanks !
FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 2a759eh
Read moreHello there,
I did the updates for Outlook and now I found this error on event properties in Microsoft Exchange. I tried to reinstall the previous version of Outlook and the error appears again. Does anyone can help me please with this error?
Thank you !
Event Properties – Event 1048, MSExchange OWA
Outlook Web App couldn’t connect Exchange Web services due to a configuration error.Response code= “500”.
Read moreHi,
I try to run Maya 2014 on my MAC and I have this error when I try to license the program. Maya 2011 and 2013 worked just fine and both like this one are licensed for Educational purpose. I don’t know what to do next so can anyone help me please to fix this error ? How can I license Maya 2014 properly ?
Thank you !
License was not obtained
Tried Maya 2014 (65F 2014.0.0.F), error 41
License method:
Environment variable
MAYA_LICENSE_METHOD=’standalone’
Product choice:
MAYA_LICENSE=’unlimited’
License file override: environment variable MAYA_ALT_EN is not set
OK
I have updated my Windows 7 (x86) and I have this error when I want to open a file, close one or simply when the program is open. I don’t want to reinstall the program because I don’t have the CD anymore so is there any other way to fix this ? What is causing this ?
Thank you !
Fatal Error: unhandled e06d7363h Exception at 75fd42ebh
Read more
