Archive
Hello there,
I have this error every time when I want to generate a MDR report and when I click OK it closes the AutoCAD window. I don’t have a solution for this so is there an expert online that would like to help me please ? Why I have this error ?
Thank you !
AutoCAD Error Aborting
INTERNAL ERROR: !dbutil.cpp@705
Read more
I have following error message when I want to install one of the Autodesk products. This is not the first that I have installed on my PC and until now I never had an error. This is the only one and I don’t know how to manage. Can anyone help me please to fix this ? Why I have this error ?
Thanks !
Autodesk Building Design Suite Premium 2014
The system cannot open the device or file specified.
C:UsersmfoxAppDataLocalTempAIA6D.tmpx64RVT2014RVT2014.msi
OK
Read more
Hello tech people,
When I try to run a registry cleaner, I got an error message pop up. I am not a technical person so having hard time with this problem. How do I fix this problem? For your information, I have Windows XP operating system 64-bit and 500GB hard disk. I have attached the error image please do help me. Thanks a lot.
::{26EE0668-A00A-44D7-9371-BEB064C98683}
Class not registered.
Read more
During the install of Autodesk INVENTOR this error appeared in the middle of the process. I have the original and licensed DVD and I think it shouldn’t be a problem. Does anyone have any idea about this error ? What is causing this and how can I solve it ?
Thank you !
AUTODESK INVENTOR 2014
Error 1335.The cabinet file Base_T—1.cab required for this installation is corrupt and cannot be used. This could indicate a network error, an error reading from the CD-ROM, or a problem with this package.
Read more
Hi troubleshooter,
I tried to download and install the Bink in the computer but I cannot do this because of this error message. When I try to run the Bink video, I got this problem triggered. The error says the program can’t start because bink32.dll is missing from your computer. Try reinstalling the program to fix this problem. Please help me. Thanks.
CoDWawmp.exe – System Error
The program can’t start because binkw32.dll is missing from your computer. Try reinstalling the program...
Read more
Hello Whizzes,
When I try to retrieve the COM class factory for component with CLSID, I got this error message. The error says it is unable to load configuration information. How do I fix the problem without any reinstallation? Hunting for solution, please help me. Your help is really great. Thanks a lot.
Error
Unable to load configuration information. Retrieving the COM class factory for component with CLSID
{69c3e4bb-acc2-41f0-85d6-403c53A38D} failed to the following error: 80040154.
Read more
Hi Brainy,
When I try to register a plugin in windows operating system using the command prompt as administrator, I go this error message pop up message. For your information, I have windows operating system 32-bit and 500 GB hard disk. The error says the DLLregisterServer entry point not found. How do I fix it? Please help.
RegSvr32
Sap 2000Plugin_CSI_Sample1.dll was loaded, but the DLLRegisterServer entry point was not found. This file cannot be registered.
Read more
Hi Expert DBA’s,
When I try to connect to a Microsoft SQL server, I ended up with an error message. In addition, I got this error pop up when I try to connect to SSIS service on machine. The error says the error loading type library dll. I have attached the error image please do check the attachment and explain me to fix the problem. Thanks a lot.
Connect to Server
Cannot connect to
Additional information:
      Failed to retrieve data for this request. (Microsoft.SqlServer.SmoEnum)
           Connect to SSIS Service on machine……… failed:
             Error loading type library/DLL.
                   Connect to...
Read more
Hi experts,
I got this error message pop up both in the client machine and in my computer when I try to install the Cisco VPN in the client machine and AnyConnect in my computer. I do understand the real cause of this error message. How do I load the vpnapi.dll? Is there any problem with the dll files? Please explain me. Thanks.
The module “Vpnapi.dll” failed to load.
Make sure the binary is stored at the specified path or debug it to check for problems with the binary or dependent .DLL files.
The specified module could...
Read more
Hello Experts,
When I try to register a dll file by using the Regsr32.exe command-line tool, the dll is not registered and I got this error message. The error says that the dllregisterserver in flvmdv.dll succeeded. How do I fix this problem? Please help me solve this problem. Thanks a lot.
RegSvr32
DLLRegisterServer in flvmdv.dll succeeded
Read more
