Archive
Hi there,
I have uninstalled AutoCAD 2014 because I have updated my Windows 7 and it messed up the program. After inserting the CD with AutoCAD 2014 and click the Next button this error appeared. Update needed- I don’t know what updates it needs and someone can help me please with this ? There is no update available to install. How can I solve this ?
Thank you !
The custom entity fix done for AutoCAD 2014 has not been applied to the AutoCAD 2014 on this machine. For CADWorx to function , this system needs to...
Read moreHi there,
I did a project in AutoCAD and I have this error when I want to save that project. The drawing is saving as .tmp and I cannot access it in that adress. Can anyone help me with this error ? Why I can’t save anything ?
Thank you !
Unable to save to drawing C:UsersRichardSharePointMargaret
FruinHDFILESHD-Clients-ActiveDanzigerDWGSDanziger_DD_Bath_Plans_Elevs_131206.dwg.
Drawing saved to C:UsersRichardSharePointMargaretFruinHDFILESHS-Clients-ActiveDanzigerDWGSsav3DF9.tmp
Read moreHi there,
I have downloaded a Language Pack for AutoCAD 2014 from the official website and I have this error when I want to install it. My program Autodesk AutoCAD 2014 is original and licensed and I don’t know why the product is not found. Can anyone help me please ? What should I do ?
Thanks !
Allied product is not found.
Read moreHello,
This morning this warning appeared on my desktop when I tried to open Civil3D. I hit the X button to close because I don’t know what file it wants to load and if will harm my laptop. Does anyone have any idea about this error ?
Thanks !
File Loading – Security Concern
An executable file was found outside of the specified trusted locations. What do you want to do?
C:Program FilesCommon FilesAutodesk SharedExtensions 2014ProductsCivil3DAREXC3DStartX64.dll
Make sure that this file comes from a trusted source and does not contain malicious code.
Load Do Not Load Help
Read moreHello,
I don’t know why is not working when I want to open a file directly from the Vault. This is the error that I have and I can skip it by pressing the Close button but it appears again and it started to be a bit annoying. Can anyone help me ? What it means and how much it harms the program when I click Close ?
Thank you experts !
Get/Checkout Errors
Unable to Get/Checkout Files
Vault2014.jpj- An error occurred while attempting to retrieve a file
Read moreHi experts,
I don’t know how to skip this error when I want to install AutoCAD 2014 on my MAC and have no idea what it means Journaled HFS+ file system. What is the solution for this error ? What Journaled HFS+ means ?
Thank you !
Install Autodesk AutoCAD 2014 for MAC
Autodesk AutoCAD 2014 FOR Mac can only be installed on system drive formatted with JournaledHFS+ (Mac OS Extended Journaled) file system.
Read moreHi there,
Every time when I want to launch any Hydraflow applications in Civil 3D 2010 I have this error and when I click OK the PC is freezing. I don’t know what should I do to fix this error and can anyone help me ? Is there an expert online ?
Thank you !
Installation Error
Invalid Installation. Program ending.
Read moreHi there,
After the error that AutoCAD gives me and closes the program this is the next error that I have when I want to open the program again. I don’t know what to do with the errors and how to get rid of them. Can anyone help me please to fix this ? What this error means ?
Thank you !
Error processing C:Documents and Setting GaryMy DocumentL01.L03_2007.0
Read moreHi expert,
When I try to obtain a license remotely for a network licensed AutoCAD product from the license server this is the error that I have. I have the full bought program with a valid license and I don’t know why I cannot activate it. Can anyone help me please ? Is there another way to obtain a license ?
Thank you !
A valid license could not be obtained by the network license manage. Try again. If you are still unable to access a license, contact your system administrator. Error [1200.5-96]
Read moreHi there,
While I was trying to make the update of my Mailbox in Microsoft Exchange Server this errors appeared and I am stuck with this. I really need to make a backup and I’ve followed the steps from the website and is not working, I didn’t miss anything. Does anyone have time to help me to solve this error please ?
Thank you !
A generic error of Microsoft Exchange Item Provider.
Error: 0x580515
IsReturnCode=1(0x1),
$module=”arx_agent_vs_34514”
Tag: 0x43308X0AE1189F4
Failed to browse Microsoft Exchange Server.
Error: 0x5B001E
Tag: 0Xe45d4302de4b8881
Cannot connect to Microsoft Exchange Server.
Error: 5B0006$module=”arx_agent_vs_34514”
Tag: 0x9F4D875A39EF5AB8
Failed to create...
Read more
