Archive
I am getting this error message in Microsoft SQL server Management Studio while working with the Interface type. The error says that the operation failed because the Query Interface call on the COM component for the interface. Please explain me to solve this problem. Is the problem with the interface type or with the component? Help please.
Microsoft SQL Server Management Studio
Unable to cast COM object of type ‘System_ComObject’ to interface type
‘Microsoft.VisualStudio.OLE.Interop.IServiceProvider’. This operation failed because the QueryInterface
Call on the COM component for the interface with IID ‘{6D5140C1-7436-11CE-8034-00AA006009FA}’
Failed due to the following error: No such interface supported...
Read more
After the running, the update for Microsoft Visual Basic I ended up with an error message while working in a project. The error message does not specific any information about the error and why it happened. The error says there is an ‘automation error or unspecified error’. How do I correct this error? Please help. Thanks.
Automation error
Unspecified error
Read more
Hi there,
I found this error report and is saying that member not found. I don’t know what this error means because I didn’t observed to affect anything but I would like to solve it. Can anyone help me please to fix this ? What it could affect ?
Thank you !
Error in rule: Rule0, in document: part1.ipt
Member not found. (Exception from HRESULT: 0x80020003 (DISP_E_MEMBERNOTFOUND))
OK
Read more
I try to run Maya 2014 on my laptop and I have this error when I try to license the program. Maya 2011 and worked just fine and I just want to use it only for Educational purpose. I don’t know what to do next so can anyone help me please to fix this error ? How can I license Maya 2014 properly ?
Thank you !
License was not obtained
Tried Maya 2014 (65F 2014.0.0.F), error 41
License method:
Environment variable MAYA_LICENSE_METHOD=’standalone’
Product choice:
Environment variable MAYA_LICENSE=’657f’
License file override: environment variable MAYA_ALT_EN is not set
OK
Read more
Sometime when I want to assign some items on my files this error 155 appears. I click OK and I can continue but the items are not assigned. Does anyone knows how to solve this ? Why I have null parameters ?
Thank you !
Illegal null parameter passed to server.
Read more
Today I did some changes into a project when suddenly I got this error message. I don’t know about what king of Internet connection is about and also I have checked my Internet connection and is working just fine. Does anyone have any idea about this ? Is there a problem with my Internet connection ?
Thank you !
Autodesk Revit MEP 2014
Error – cannot be ignored – 2 Errors, 0 Warning
The family is connected in a network and can no longer keep the connectivity. Disconnect the family from the network?
Show Expand>>
Disconnect OK Cancel
Read more
Hi experts,
I just installed on my laptop Windows server 2012 and I have this error when I want to launch the server. Somehow it seems like DOTNET4 missing and I expected that a fresh install of Windows will be complete. Any solution for this error ? Why I have this error ?
Thank you !
Error
Section DOTNET4 is missing!
Read more
Hello experts,
Today I made a fresh install on my laptop with Windwos 7 and when I want to install AutoCAD 2014 Civil 3D this error appeared. I have the original CD and license and I was expected that I could install the program again. Can anyone help me with this ? Why I cannot install ? Should I buy a new cd-key ?
Thank you !
Installer information
AutoCAD Civil3D 2014 or Map 3D 2014 must be installed for Storm and Sanitary Analysi 2014 to be installed.
OK
Read more
Sometimes I have this error and sometimes I don’t have it. It appears when I want to access some files from my PC and this system error doesn’t let me to make it. Any solution for this ? What is divide by zero error ? Is this a virus ?
Thanks !
System Error
Divide By Zero or Overflow Error
Read more
Block definition gives me this error about unsupported characters. I’ve started to use this program because a friend of mine recommended and I am a newbie with this. Does anyone have a solution for this error ? How can I skip this ?
Thank you !
Block – Unsupported Characters
The name contains unsupported characters. The following characters are not supported:
Read more
