Archive
I was working on my important final presentation while working on the Microsoft Word. Now I am unable to open the Word document shows me the following error message when I try to open this file. Any help would be appreciated.
Microsoft word
The file Marketing plan(Fixed) cannot be opened because there are problems with the contents.
Ok Details
Details
The name in the end tag of the element must match the element type in the start tag.
Read more
Hi experts,
When I tried to run excel VSTO project within Visual studio, the excel file opened with an error message. I closed the excel file and restarted it within VS again but the same error displayed. I am using the latest version of VS. Any suggestion would be helpful to demolish this error.
The customization assembly could not be found or could not be loaded. You can still edit and save the document. Contact your administrator or the...
Read moreHi,
I am running Windows 7 Professional 32 bits and trying to run Windows Update. When I click to install an update for the requirement of Windows Update then I receive the following error message “Windows could not search for new updates”.
I need your help to resolve this problem.
An error occurred while
Checking for new updates for
your computer.
Error(s) found:
Code 800B0001 Windows Update encountered an unknown error.
Read moreHi,
I am getting the following error while connecting the LogisticsAddressDistrict table in MS-Excel through Add-on.
I want to remove this error so I need your help to resolve this problem.
Dynamics AX Error
Cannot load [LogisticsAddressDistrict].
Tables must have a valid replacement key or primary index other than RecID for use in the Office Add-ins
Read more
I am familiar with Linux environment and I got the following error message when I updated to version 4.0. I tried to reinstalled but still found the same error. Any help would be appreciated.
Error
Sorry, manage sieve filtering not supported on imap.googlemail.com using port 2000
Read more
Hi experts,
When I tried to download templates in Word then I got the following error message. I checked all the following issues to fix this problem but still same problem appeared. I need your help to fix this issue.
Template Download Error
The template cannot be downloaded. To fix this problem, do the following:
*Make sure your computer is connected to the internet.
*Make sure your browser is not in office mode.
*Try download the template again later.
Was this...
Read more
When I click this link https://www.microsoft.com/web/handlers/WebPI.ashx/getinstaller/OfficeToolsForVS2012RTW.appids , I get the following error message from Microsoft Web Platform Installer 4.5. How do I resolve this error? Any help would be appreciated.
Web Platform installer 4.5
Microsoft web Platform installer couldn’t find the product your tried to install. Either the link you clicked is incorrect or your may be Overriding your feed with a different feed.
To learn more about custom feeds and how to reset Microsoft web Platform installer Chick here.
Read more
Hi experts,
I have downloaded Microsoft Office Home and Business 2010 but when I attempted to install the Setup then I received the following error message during installation. I want to fix this error immediately.
Thanks in advance.
Microsoft Office Home and Business 2010 encountered an error during setup.
Error 1935. An error occurred during the installation of assembly component
{e9192F0E-035C-32C5-A6AZ-6D781EE24B3D}. HRESULT: 0x80073712.
Read more
I have successfully installed Autodesk Vault Office 2012 on the ADMS Server and on the Clients where an office application (such as MS Office 2010) is installed. I tried to login from the office and got the following error message. Help me to fix this error.
Failed to acquire a license.
Read moreHi,
I am using Windows 7 and experiencing an error while open the Word file.
The following error message says to try some suggestions but could not fix it.
I need your help to fix the following error so that I may continue my work.
Microsoft word
Word experienced an error trying to open the file
Word experienced an error trying to open the file.
Try these suggestions.
*Check the file permissions for the document of drive.
*Make sure there is sufficient free memory and disk space.
*Open file with the Text recovery converter.
(C:/…/Premera Washington Enrollment…)
Show Help.
Read more
