Archive
I am trying to access Vault Server version 16.0.56.200 from Excel 2007 but when I attempt to login, the following error message appears. I am running Microsoft Server 2008 Operating System. I need your help to demolish this problem.
2007 Microsoft Office system is not compatible with the usnbrvault hosting the following server applications:
Vault Server Version 16.0.56.200
Read more
I am having trouble during uninstalling the program. When I attempt to uninstall Office Scan program, it gives me the following error message “Unable to get uninstallation information (Mote). Uninstallation aborted”. I tried many times to uninstall this program but still shows the same problem. Suggest me if you can.
Trend Micro officeScan Uninstallation Unable to get uninstallation information (Mote). Uninstallation aborted.
Read more
I have installed Libra office 3.6 with having no problem but when I tried to execute it and got the following error message “Unhandled exception”. I tried many times to fix this issue but could not fix so I need your help to resolve this matter. Thanks.
Unhandled exception:
Invalid RegistryExeption:
File:///C:/ Program%20Files%20(x86)/LOFFICE/program/../share/extensions/NLPSolver/components.rdb:duplicate<implementationname=”com.sun.star.comp.Calc.NLPSolver.DEPSSolverImpl”>
Read more
I have recently installed the Open Office and tried to create a new database. When I attempt to open the database then, the following error message appears “JRE is Defective”. I extremely need your help to resolve this issue.
Thanks in advance.
LibreOffice requires a java runtime environment (JRE) to perform this task. The selected JRE is defective. Please select another version or install a new JRE and select it under Tools- Options-LibreOffice – Java.
Read more
I am using iMac and running Final cut pro X on my system and I want to export video using this software. I can’t do anything with this video until I export it so I urgently need your help. The following error appears when I try to export video. Any help would be appreciated.
The operation couldn’t be completed. One or more projects or events were created with a newer version of final cut pro...
Read more
Hi experts,
I have installed Microsoft Visual Basic software and when I tried to install other related software, it displayed the following error message “se information for this component not found. You do not have an appropriate license to use this functionality in the design environment”. I want to remove this error so I extremely need your help.
License information for this component not found. You do not have an appropriate license to use this functionality in the design environment.
Read more
I have downloaded PowerPoint files and when I click to open these files, an error message appears every time. When I clicked on Repair another error message displayed. I am confused how to remove this error so help me to resolve this error immediately.
PowerPoint found a problem with content in………….pptx.
PowerPoint can attempt to repair the presentation.
If your trust that source of this presentation, click repair.
Read more
When Windows tried to activate, an error occurred which I have encountered many times and can’t solve. I need your suggestion to fix the following Windows Activation error. Any help would be appreciated.
Thanks in advance.
The following information was found for this error:
Code: 0x8007232A
Description:
DNS server failure.
Read more
Hi experts,
I have a problem with my Office 365 and the problem exists as long as Outlook.com went live. I get the following error message when I try to access the account. I really need help to fix the following error message so that I may proceed. Any suggestion would be helpful. Thanks.
This Account can’t be used to access outlook.com
You’re currently singed in with an Office 365 email account, which can’t be used with Outlook.com. please...
Read more
I tried to install Microsoft SharePoint Server 2010 on a server, and I received a following error message “The language of the installation package is not supported by your system”. I want to remove this setup error so I need your help.
The language of the installation package is not supported by your system.
Read more
