Archive
I was installing the version v5 of Advanced System Care, and I had my uncle's disk in here, so I was installing, and it’s installed on my uncle's disk.
Then my uncle ejected his disk, and when I was installing on my PC this error came up:
So I click OK and the installer close itself...
BTW in the error says:
The selected UNC unity doesn't exist or isn't accessible.
Is there any way to fix this issue? Thanks.
Error
A unidade ou partiha UNC seleccionada nᾶo existe ou nᾶo estᾴ
acessivel. Seleccione outra.
OK
Read more
I am having trouble and receiving error message whenever I try to install a program. After few seconds installations stops and shows the following error message “Documents is not a valid short file name”. Any idea would be really appreciated.
Error 1325.Documents is not a valid short file name.
Read more
Recently, I bought Rpj model few days ago with 8GB SDHC card. When I tried to flash Resbiani accidentally flashed compressed .zip file but I changed its name as .img and flashed it. Now I am unable to use SD card on any system. How can I overcome this problem? Help me to resolve this issue. Thanks.
There are some error occurred while Writing partition chains on disk
Error
Writing partition chains on disk.
OK
Read more
Hi experts,
I am getting system error message when I double click on atf icon for open Software. The following error message gets appear “Access is denied”. How can I fix this error? Any help would be appreciated.
Thanks in advance.
System Error. Code:5.
Access is denied.
Read more
I am getting the following error message when try to uncompress file. I tried it on Windows Vista, 7 and XP but the same error message appeared. How can I fix this issue? Any help would be really appreciated. Thanks in advance.
Checksum error in Application2BinDebuapp.publishbinMicrosoft.LightSwitch.CodeMarker.dll
ZipGenius 6
OK
Read more
I have just used ZipGenius to open the Thunderbird omni.ja file (after renaming it to omni.zip) and I think that there is a bug. When I try to expand the folders in the Folder View I get the following error message after expanding:
- Chrome
-- Chat
--- Content
-- Skin
--- Classic
---- Chat
Any idea would be really appreciated. Thanks in advance.
Access violation at address 0089C57C in module ‘zipgenius.exe’
omni.zip - ZipGenius 6
Access...
Read more
Recently (as of a few days ago) I've been getting an error dialog every time I log into Windows (Windows 7 if that's of interest). I haven’t installed AutoIt myself, so I'm assuming that it's been installed as a dependency for another program. Any help would be really appreciated. Thanks for any help.
Error: Array variable has incorrect number of subscripts or subscript dimension range exceeded.
AutoIt Error
Line 207 (File "C:WindowsStartup.exe"):
OK
Read more
When DP Finisher reached at the end of RunonceEx I got the following error message. Any Help would be greatly appreciated. Provide me the proper way to resolve this error. Thanks in advance.
LINE 0 (File "C:DPsFnshr.exe"): timerStop($tmpTimer) ^ERROR
^ERROR
Error: Unknown function name.
Tamam
Read more
While using Universal Extractor I have encountered with this error. How can I get rid of it? I'm running Windows 7 pro 32 bit. Would any other information be helpful? Thanks in advance.
The archive is corrupted, or invalid password was entered
Universal Extractor Setup : Error
7-Zip: Data error.
The archive is corrupted, or invalid password was entered.
OK
Read more
Recently, I bought Acronis Migrate Easy. I installed this program and after reboot I started it an error message displayed. How can I fix this error? Any help would be really appreciated. Thanks in advance.
Acronis Migrate Easy does not support Windows Dynamic Disks, EZ-Drives, etc.
Error
E000101F4: Acronis Magic Easy has detected unsupported hard disk
Drives. Acronis Migrate Easy does not support Windows Dynamic Disks,
EZ-Drives, etc.
OK
Read more
