Archive
I am running Windows 7 Operating System with IE 8 and I got the following error message when I tried to install EndNoteWeb 3.0 on my machine. What could be the causes? How can I fix this properly? Need your assistance as soon as possible.
Thanks for any help.
Error 1904.Module C:program filescommon filesMSSoapBinariesSOAPISAP.dll failed to register.
HRESULT – 2147023782. Contact your support personnel
Read moreHi,
I am having difficulty connecting to the organization using the CRM Adapter V5. I have spent so much time to resolve this issue but I could not find any solution I have used different unique name to connect but I received the database error. Now I really need your help to fix this problem.
Thanks in advance.
Database Error
Error Number:104
Description:
Error opening data source scribe.MSCRMAdapter30.Database
(http://crm01/-GEN).
Native error:0
Source:
ADP
Read moreHello,
I am just getting this error on the startup of MyEclipse. I have not seen this error before when I click on details I got the following errors. This problem occurred saying “Building workspace has encountered a problem”. I have spent a lot of time to resolve this error but I could not so please provide any way to fix this issue.
Thanks in advance.
Building workspace has encountered a problem.
Errors occurred during the build.
Errors running builder Android PreCompiler on project storm.
Java.lang.NullPointerException.
Read moreHi,
During the installation I received the following error message
Database connection error (2): Could not connect to MySQL.
I have entered the MySQL database details correctly but I could not connect. What is wrong?
Can I get the possible solution?
I am waiting for your resolution. Any help would be appreciated.
Read moreHi experts,
I got this weird error message when I tried to enter a website in a forum. I really need a detailed solution to resolve this issue as soon as possible. The error shows “MyBB has experienced an internal error and cannot continue”. How can I fix it?
MyBB has experienced an internal error and cannot continue.
Error type:
MyBB error (40)
Error message:
Your board has not yet been installed and configured. Please do so before attempting to browse it.
Please contact the MyBB group for support
Read moreHi,
I am using Visual Studio 2010 C++ but during the programming, I got the following error message “Debug Assertion Failed”. Did I something wrong? I really need your help and want to remove this error. Provide possible solution.
Thanks for any assistance.
Debug assertion failed
Program:…
File: c:program filesmicrosoft visual studio 8vcincludevector line: 756
Expression: vector subscript out of range
For information on how your program can cause an assertion failure, see the Visual C++ documentation on asserts
(Press retry to debug application)
Read moreHi,
Today, I was trying to install VMware VPD for SQL Server Setup but I was unable to install it properly because during the installation an error message appeared saying “Unable to register the backup agent service”. I could not resolve this error so I need your assistance to fix it properly. Provide any suggestion.
Thanks in advance.
Register Agent: Unable to register the backup agent service.
Read moreHi,
I am running Windows 8 Operating System and use JW Player 6 to play MP4 files but today, I got the following error message when tried to play mp4 files. It was not working and displayed the message “Error loading media: file could not be played”. I am not able to play these files on Chrome with HTML 5 mode in JV Player 6 but on all other browsers. Have any idea? How can I fix it? Any help would be appreciated.
Error loading media: File could not be played.
Read moreHi,
I received the following error message when I was trying to import data from my BigCommerce Store. I have setup the BigCommerce connection inside Ordoro correctly. I have tried many ways to resolve this issue but unable to fix it. Can I get the solution for the resolution? I am waiting for your suggestion.
Thanks for everything.
An error occurred. Please contact ordoro support. Details: you have not set permissions inside your bigcommerce panel correctly. Please see this help article to learn more
https://support.ordoro.com/customer/portal/articles/990709bigcommerce-401-client-errorunauthorized
Complete 0 minutes ago
Read moreHello,
Today, I was attempting to extract a zipped file in a folder but an unexpected error was displayed. I have searched the solution online but I couldn’t find anything. Can I get the resolution from your side? I need your support to handle this issue.
I would be grateful to you.
An unexpected error is keeping you from copying the file. If you continue to receive this error, you can use the error code to search for help with this problem.
Error 0x80004005: unspecified error
Type: PNG image
Date modified: 9/6/2012 9:26PM
Read more
