Archive
After using Google Chrome for quite some time now I decided to try and install Opera. It works perfectly for me though until today. I am faced with the error message that says “Crash log writing failed, couldn’t debug process! Error description from system: The parameter is incorrect”. What happened to my browser?
What will I do so that I will not be able to get this error message again?
Crash log writing failed, couldn’t debug process! Error description from system: The parameter is incorrect.
Read more
I just found out this new software for customizing my OS called Rainstaller. Within my unit I have installed Rainmeter as a defacto of the software. Now the problem that I have at hand is that there is an error message while I was trying to backup my files.
What seems to be the problem with this? I posted a here the error message.
Is there a quick fix for this error?
Rainstaller
Unable to create file: Backupf2Oll.11.1O 01.59-51/Space/iTunes Monitor 03 by urieIHDS/iTunesArtworkfThumbs.db
OK
Read more
I am not new to AutoCAD and its other products but this one puzzles me. I am trying to install AutoCAD Mechanical 2012 on my work station twice now. It is really a long and tedious process if I may say so. After hours of waiting it wouldn’t finish installing and keeps showing an error.
I have attached herewith a screen shot of the error. I hope you can help me with this matter.
I am really getting frustrated with this matter. I am trying to install Autodesk Inventor 2012 on my unit and I keep getting the same error over and over again. Is there any other way for me to install this software?
I pasted here a screenshot of the error message. I badly need this to work.
Thanks in advance.
Hello everyone. I am currently an architecture apprentice/ intern working in a firm. They have asked me to use Autodesk Revit Architecture 2012. While working with a file that my boss gave me from his PC and error message popped out saying that I have to run the installer again on my workstation for this to work.
I currently don’t have the media for that. Is there another way to fix this? Can I just download the missing file?
Thanks in advance.
I have installed adobe air for quite some time now. Now it asks me to download a patch for it. After doing so an error message pops out.
I have already tried it twice and still the same error persists to occur. What seems to be the problem with this?
Is there another patch for my system that I need to download first?
I was browsing this website that I needed for work. It then prompted me to install Adobe Air. As I was installing it an error occurred while installing the said software. I really need to view the website and without this I will not be able to do so.
Help is badly needed and is there a fix for this? I have posted the error that occurred below.
I just installed Panda Cloud Antivirus to my new Dell Inspiron Laptop yesterday.
It works perfectly until today. Currently it is saying that the console cannot open and the antivirus is not operating correctly.
What seems to be the problem with the software?
Thanks in advance.
I just finished installing Adobe Premier Elements to my friend’s laptop. After the installation had finished a message box appeared saying that there is an incompatible driver display. What seems to be the problem with this? Is this software or a hardware issue?
Your response will be highly appreciated.
Hello Excel Expert,
I want to write a comment in excel footer without using header & footer option.
I want to write the comments using code.
My question " HOW CAN I WRITE THE CODE & WHERE I WRITE THE CODE" for Example I want to write "Powered by Tareq" when I print the excel sheet then print the
Powered by Tareq" in the footer.
It is printable but not visible.
Ok, thanks,
Have a good time.
Read more
