Archive
I have an issue that I can’t begin explaining because I do not really understand why it happens in the first place. The problem is that there is an error that occurs when I start my computer. I have been playing around with Matlab computing language and maybe this has something to do with the error. I need experts to shed light on this please.
Fatal Error
SIGSEGV ‘segmentation violation detected. Address be4ccd01
Read more
I am having problems installing Avira Free Antivirus downloaded from the internet. The error is as shown in the image below.
How do I fix this?
The installation of the LSP failed. AntiVir MailGuard and Antivir WebGuard therefore cannot be installed. We recommend that you repair the LSP stack and the reinstall AntiVir MailGuard and AntiVir WebGuard via the user-defined installation.
Read more
I wanted to install Lightroom 4.1 on my computer but when starting the setup I get an error as shown below. I have tried to empty the disk and now I have more than 20 MB available but still see the error as it appears. Am stranded because I had already checked system requirements before downloading it.
Disk Space is Low
Your disk “Vista (C:)”, which contains your Lightroom catalog, is critically low on space
Please remove files or empty the trash to make at least 20 MB available.
Read more
I have Flip4Mac installed but I get an error when trying to play a DRM (Digital Rights Management) protected file from Facebook. I got a screen shot of the image and it is attached below. I would really appreciate all suggestions on this issue.
There was a problem connecting to Facebook.
The operation couldn’t be completed (OSStatus error -1)
Read more
I wanted to produce a small film using the AVID Media Composer but then the program is behaving weird and displays an error sometimes on launch or when opening a file. I got a screenshot of the error and it is shown below. Please have a look and suggest something that can be done about it. I have Windows 7 installed.
Avid Media Composer
Exception: DesktopSFConsumer::EarlyPreSync error PreLoading spring buffer.
Read more
I have encountered an unfamiliar error on my Windows 7 that I can’t explain why it happens. There is a random error that keeps on popping up either when I start my PC or after my antivirus has started. I am using AVG and I do not know if it is causing this problem. I just thought of asking the experts here so that I can get all possible causes of this error shown below.
Error Error
An error occurred while displaying previous error
Read more
FreeHand is a great tool for creating illustrations and layouts for printing or Web and I have used it for some time now but it has been giving me an error recently. I cannot seem to be able to transform objects and when I try to do so the error below shows up. Please help with your suggestions.
A transform has been applied to the object and the original object cannot be subselected. Use the Reset Extrude command to remove the transform
Read more
I have been using Microsoft Office 2007 on Windows 8 but the Access is having issues. I have attached an image for you to see and suggest a solution. I am always getting this error even immediately after opening access. I was handed this computer by a friend with everything already installed.
Microsoft Access
The Microsoft Jet database engine does not recognize ‘tblStaf.*’ as a valid field name or expression
Read more
There is a warning message that pops up when I browse pages on the internet. I managed to get a screenshot as shown below. What is causing this warning to appear? It is getting my system slower in performance.
It happens randomly and I can’t figure out a specific site that causes it.
Warning: Unresponsive script
A script on this page may be busy, or it may have stopped responding. You can stop the script now or you can continue to see if the script will complete.
Script: http://ds.serving-sys.com/BurstingScript/ebPreServing.js:32
Read more
I created an apple script to be able to switch between two Wi-Fi networks. The script however displays the error below. Can I get any advice on way forward?
AppleScript Error
The variable theDataSource is not defined. (-2753)
Read more
