Archive
F-spot is a tool that I have used to organize and share my photos with family and friends. But recently, it has been quitting unexpectedly and on clicking Restart Application it pops up the error again in a loop. What other options do I have here?
Error
The application “f-spot” has quit unexpectedly
You can inform the developers of what happened to help them fix it. Or you can restart the application right now.
Read moreHello,
I wanted to use GIMP image manipulation program but I keep getting an error as shown below. I am a novice with this software so as you explain all I need to know please be simple. Why am I getting this error?
GIMP Message
GIMP MESSAGE
Failed to create thumbnail folder ‘/home/yuv/.thumbnails/normal’.
Read moreHi,
I would like to know more about the HP Photo Publisher with regards to adding photos to an existing album. I have been getting an error as shown in the image below. I have tried restarting but no luck yet.
HP Photo Publisher
An Error Occurred.
An error occurred that prevents you from going any further. Either go back and try to correct the error, or try to restart from the beginning.
Some errors occur because of problems with remote sites. Please try again later if you suspect the remote site is having issues.
Error Message: Forbidden
Read moreHi,
The 3ds Max is a good modeling and rendering software. I downloaded and installed it on my computer but then I could not launch it because of the error shown below. I tried to restart my computer but then still got the same error. Please advice on what to do.
3ds Max
The software license failed to initialize. [Error 7]
Read moreHello,
Lightroom 4.1 has been giving me an error as shown below. It says Master Catalogue cannot be opened. Is there a quick solution for this so that I can stop worrying? It is a good photo software and I would like to resolve the problem soon.
Lightroom cannot open the catalog named “Master Catalogue” located on volume “Photography” because Lightroom cannot save changes to this location.
Lightroom Catalog cannot be opened on network volumes, removable storage, or read only volumes.
Read moreHi,
When I open Camtasia Studio I can’t record any screen activities on my computer because am getting an error as shown below. What graphic card is needed here? How do I know it is compatible with Quartz Extreme?
Quartz Extreme Required
Camtasia requires a graphics card that is compatible with Qartz Extreme. One or more of your graphics cards does not support Quartz Extreme.
Read moreHi,
Lightroom has made photo editing and management easier for me although there is an error that occurs when saving adjusted photo. The error is as shown below. Is there a quick fix to this? It keeps on displaying the error every time.
Error saving adjusted photo
Received exception “URL could not be converted to local file location”> Note that you have to develop RAW files into JPEG before you can edit them.
Read moreHello,
I like the Zoner Photo Studio 15 that helps me in all my photo activities and management. However yesterday when I tried to open it an error occurred. I restarted my computer and the program too but this didn’t solve my problem. Any ideas?
An unexpected error occurred in the plugin.
Read moreHello,
I am disturbed here with an issue with my iPhoto library manager. I have a particular library that won’t open at all. It pops up a message shown in the image below. How can the compatibility issue arise when the library was also created on iPhoto?
iPhoto is unable to open this library
The library is not compatible with iPhoto
Read moreHi all,
I am always getting an error when I try to open Teamviewer 6 which I downloaded from the web and installed successfully.
I tried to reinstall it and see if error goes away but no it is still there.
How would I resolve this?
An error occurred during the initialization of TeamViewer. Probably
Some security software blocks network communication on this computer.
Please permit network communication on this computer to use TeamViewer.
Read more
