Archive
I was not able to perform a scan using HP scanner due to an error that occurred. I managed to get a screenshot with further details. Please see image and advice me appropriately.
The scan cannot be performed because another program or computer is using the networked HP imaging device. Try again later.
4[(0,400,80004005),(2,33,80040013),(3,33,0)]
OK
Read more
I was trying to upgrade from old Zbrush 4.0, which is a digital sculpting tool with both 2D and 3D support, to the latest 4R5 but am faced with an error as shown in the image below. Any suggestions?
Zscript Note: interface item could not be found
SCRIPT: QuickSave4.txt
Error 5570
IN: [IGetTitle,5570]
Read more
I have the EPSON printer and while trying to install drivers I get error 1797 saying the driver is unknown. What suggestions do you have about is causing this problem? All drivers I get from EPSON official website.
Unable to install printer EPSON TM-U325 Receipt Error code= 1796.
The specified port is unknown.
Read more
Hi everyone,
Office communications server web conferencing edge service is showing an error and is unable to start. I was trying to configure Web conferencing edge service. The error am getting is a socket access error 10013. Any ideas?
Could not start the Office communications server web conferencing edge service on Local Computer.
Error 10013: An attempt was made to access a socket in a way forbidden by its access permissions.
Read more
I have the EPSON printer and the installation of drivers quits halfway with the following error below. If I click OK the installation stops. Tried several things like restarting the application, disabling firewall etc but it has worked. What can I do?
Unable to install printer EPSON TM-U325 Validation Error code= 1796.
Read more
Hello everyone,
I have been using Adobe products for some time now and I like Photoshop most. Adobe After Effects has been giving me errors when launched. This just happened a few days ago and I had used it for some time. Any suggestions? I already did a reinstallation but didn’t work.
After Effects: AEGP plugin Media plugin:
There is a mismatch between Output Module settings and Transcode settings. Please verify your settings and try again.Invalid framesize/framerate for this level. Please lower the frame dimensions, frame rate or increase the profile and level and try again. MediaI02...
Read more
I purchased the full version of Malwarebytes and installed but after installation, while trying to enable the protection module I get the error shown below.
[StartService] Failed to perform desired action error code 1068
Read more
I am getting a login error when trying to login to ICAP. After providing username and password an unpredictable error occurs. What can I do to counter this error?
Unexpected error occurs:- 2147217865([Microsoft][ODBC SQL Server Driver][SQL Server]invalid object name ‘US’)
Execute Error
Do you want to quit (the database will be closed properly)?
Read more
CCDAutopilot software is a complete imaging automation program that we (me and 2 other partners) use for research. We got it working properly for a few days but recently it has been displaying the following error when launched.
Link to software error, the SkyXAdapter.StarChart1:COleException: Type mismatch.
(80020005) SCODE:80020005
Read more
Hi all,
I have been using Mac and am now on OS X Lion but suddenly my Mac shuts down automatically and just before it goes off I get error 1708 as shown below. I do not want to stop using OS X so please advise me.
Error:- 1708.File Juicer got an error: Can’t continue<event juicjuic>
OK
Read more
