Archive
My Server runs with Windows Server 2003 and there are up to hundred clients which all runs with Windows XP. Some of the client computers are replaced and the OS for the replaced system is Windows 7 only. It is loading printers & network shares. But it is not loading a roaming profile which is available in the Windows XP. I think it may not be compatible to run Windows XP and Windows 7 computers within the same roaming profile. Please help me to solve this problem. I will be thankful to all for the help and support.
Read moreI am using the Server as domain controller and as file server which is running with Windows 2000. All the things are in this server. Recently I have bought a Server which is running with Windows Server 2008. However, I don’t know how the migration is to be done. So, please help me to upgrade the server 2000 to server 2008. I am looking for step by step instruction. Thanks in advance.
Read moreWhen I am trying to connect remotely to domain controller with Windows Server 2003, it fails to connect and there is an error message displayed which says ‘Because of the network problem or it is not enabled to connect the client to remote server, it cannot be able to connect’. I cannot connect to my two virtual servers and also to another server which has connected to that server. It is also possible to get into VMware and able to view the domain controller. I have doubt that somebody changed the group policies. If anybody knows the solution to...
Read moreI am facing problems with my Cloud Distributed offshore Server. The processor is 2.8 GHz 3 Core AMD and RAM size is 3 GB. All the times HTTP web proxy auto discovery service is getting into hang state and it is not giving any error messages. The information is available in the event log only. When this problem happens, the server is losing connectivity up to fifteen minutes and it comes back with the auto star service. If anybody knows why this is happening, please let me know. Thanks in advance.
Read moreI am looking for help to set up WAN connection with Windows Server 2003 through ‘RRAS WIZARD’. I have installed two network cards, but the problem is I don’t know how it can be configured. I am using DSL Modem for internet connectivity and there is no router installed. There are four ports in the DSL modem. Server IP is 10 dot 10 dot 10 dot two, MASK is 255 dot 0 dot 0 dot 0, Def. Gateway Ten dot Ten dot Ten dot 1 and DNS is 10 dot 10 dot 10 dot 2. These are the network...
Read moreI am looking for help to import groups & users to Server 2008 system from Server 2003 system.
Is it possible or not?
There is no domain created and so we are installing another server.
So, I want to import all users to the new one otherwise I have to add all users and users groups manually.
I have searched for some help, but none was found.
I will be thankful for all the help and support.
Read moreMy operating system is Windows R2 2003 and I have installed the IBM X 346 server. Every time I am switching on the server it is not properly booting up and gives some error messages which says ‘PXE51 / DHCP’, ‘It is not received DHCP’. I don’t know why this is happening. Please help me to get out of this problem. Thanks in advance.
Read moreMy computer runs with Windows Server 2003.
Every time I try to execute ‘.vbs’ file, an error message is displayed which says ‘Access Denied’.
I think spyware is blocking the ‘wscript.exe’.
I have run the ‘wscript.exe’ from its original path which is in the drive ‘C’ ,
‘Windows’ folder and ‘System 32’ folder, but the same message is displayed again.
Also, I have executed within the administrator account, but there is no change in the result.
So, please help me to sort out this problem.
Thanks in advance.
Read moreWhen I am connecting to iTunes, iTune is not able to find any updates hence I have downloaded the update file and tried to update with the downloaded file. But an error message is displayed which says that ‘It is not compatible’. Also, there is nothing shown after the message. I am sure about the downloaded update file as it is for 3 G S only.
I have also checked in the forum, but there is no information available. I am using HP 6830 which runs with Win – Vista and it has completed all updates.
Please help me to get...
Read moreI have added applications and tried to synchronize, but I got an error message. ‘The copy disk attempt has failed. It is not able to find the required disk’. I have un-installed all the applications but the message still comes. There was no problem until some days ago. Please help me to sort out this problem. Thanks in advance.
Read more
