Archive
I have Eclipse and its plug-in which is the Subclipse that are both up to date with Debian Etch.
I am having issues when trying to add a new SourceForge SVN Repository. It seems that there is a problem with the validation.
Can someone please help me understand what the error is trying to imply?
And I’m hoping for a resolution too.
Error validating location "org.tigris.subversion.javahi.ClientException: svn: PROPFIND request failed on '/svnroot/surveyos' svn:SSLv3"
Keep location anyway?
Yes     No
Read more
Hi. I upgraded my MS Office 97 to 2003. I successfully installed it but received an alert after opening MS Word. Clicking on the Ignore button will quit the alert message and continue working. But every after opening Word, I am getting the same message. The error seems related with MS Access database which I don’t fully understand. What do I need to configure to be able to resolve the issue? Help me.
Error:
Microsoft Office Word 2003
Error 1919. Error configuring ODBC data source: MS Access Database, ODBC error...
Read more
I installed Vidalia for my Tor software. Tor automatically opens when starting Ubuntu. Vidalia will confirm if I have an existing Tor and will connect to Tor control port. But I need to customize the Tor first to be able to allow Vidalia in connecting and start using it. But while doing this, it just quit and stops working. How can I fix this? Can anyone help me?
Vidalia Control Panel
Status
Tor is not running
Unexpected Error
Vidalia...
Read more
how can i resolve the problem of IP addressing on my computer. The server i am using is set to automatic but every time i switch off my computer and then on again, i cannot connect to the network. I have checked the cables for connection and also tried manually setting up the address but still no solution.
please help.
Read more
I’m having an error when starting my Home Seer HSTouch Interface Design Software.
It is so frustrating since I purchased this software for $199.95.
If I am correct, does the error is stating some issues with JAVA?
I encountered an almost similar error before but not with HSTouch software and manage to resolve by a friend.
If anyone here who has an idea on how to fix this, Can you help me please?
Thank you.
HSTouch Designer - Sample-Project
Unhandled exception has occurred in your application. If you click Continue, the application will ignore this error and attempt to continue. If you click Quit, the application will close immediately.
Object reference...
Read more
I had an error when launching Real Time Audio Suite 4.20.3. I have had this error since migrating to Windows Vista Business Edition 32-bit OS. When I restarted the program, it just keeps looping on the same message. After this error, I am also having an unfamiliar error which I never had even before. The error says “DAE interface not available (stubbed).” How can I fix this? Do I need to re-install Audio Suite? Help please.
Exception: A serious error has occurred!
Avid Media Composer
Exception: A serious error...
Read more
When I am using Server Management Console in Small Business Server 2003, I encounter some problems. When I am clicking on a user to change the permission a wizard will come and permission can be changed through that wizard. But now, when I am clicking next in the wizard, the server was waiting for some time and getting disappeared after that without giving any error messages. If anybody knows the solution to this problem, please help me. I will be thankful for all your help.
Read more
I am using 32 bit Windows Server 2003 in the server.
It was showing in the domain list without any problem.
But, suddenly it is not showing in the domain list.
So, I have to access it through the ‘run box’.
How can I activate or restore the same to the domain list.
Read more
My server is facing boot up problem. When it is booting up the Windows Server 2003 logo is coming and the screen just shows blank and remains on the blank screen. I have done the ‘check disk’ on the server and it shows an error is fixed. But even after that it is not able to boot up.
When I am trying to boot up in safe mode it is getting hanged. I have reinserted the RAM and battery, but there was no change in the result. Even after I have disconnected and connected again Alice peripherals, the...
Read more
I am looking for help to use RRAS server which can act as router for the test purpose. So, I can connect my laptop through it without connecting to the modem. I have tried some tricks but no use. Please I request for somebody to help me in doing this. I will be thankful for all your help. Thanks in advance.
Read more
