Archive
I received this error message: "License Application Disaster - Application Disaster please attempt reinstalling" but re-installing is not functioning. What should I do?
Read more
Hello, I am working with Blend 4 (final edition) Silverlight Q1 2010 SP1 and I cannot revise scheduled templates on it.
First issue: if I do "change added layouts" -> "Edit TimelineTemplate" -> "Edit a copy" (cf 1_EditTimelineTemplate.png), I have a ControlTemplate empty (cf 2_EditTimelineTemplate_Result.png).
Is this normal?
2nd issue : Because of my primary issue, I've changed the  TimelineTemplate from "Seven theme" found in "TelerikRadControls for Silverlight Q1 2010 SP1ThemesWindows7ThemesWindows7Scheduler.xaml
and I receive an error message: (cf 3_EditTimelineTemplate from SevenTheme.png)
Please help.
Read more
I am using Epson RX500 and I received an error message reading "Printer fault-see your records or telephone assistance if needed". The red Led light is on and the printing device is not gathering the list at all. My printing device is now 16 weeks old and out of the manufacturer's guarantee.
Service was pointless because all they want me to do was to remove and re-connect to the printing device which would not work. I have tried to use the SSC Service Power but it does not function with the RX500. I have explored on the internet; however can't discover any way to reset my printing...
Read more
Hey,
My apologies to keep asking questions but I have the test edition of Socrates and I triggered it on my website mymarketingmania. It was performing well earlier but now it says it isn't activated. I have only got it two times. When I switched it on it said I can't use that initial value because it was already used. However,says I need to initialize Socrates.
Read more
Hello all
I have applied Shrink-A-OS application to decrease the dimension of the 862. Then, I chose the applications and dialects which I wanted to remove and visited on Reduce My OS. However the Arabic and English dialects are still there with the following error message. Can anyone help me out of this problem?
Read more
Hello
I am working with Windows 2008 and whenever I try to Sign Up I receive the following error message. Can anyone help me sort out the problem?
Thank you.
Read more
I'm publishing this concept after several problems in establishing my VPN network on my iOS gadgets (both my iPhone and iPad). The VPN network is operating incredibly well on my PC, so I think that the machine or my options (ID and passwords) are appropriate.
I have also tried to get some assistance from some of my friends but they are also unable to fix the problem. I guess, it would be better to publish my websites created in both PPTP and L2TP network method. Anyone could inform me where did I go wrong and how to address the issue.
Read more
I have recently purchased a new cell phone Samsung Star Wireless and I set up the application Samsung PC Business.
But it was not functioning with computer which has Windows 7.
Every time I receive the message reading “This application might not been set up perfectly”.
I have tried to uninstall the application with the secure method but with the same outcome.
How can I remove the Samsung application (Mobile Blend System application, Switch System software).
Program Compatibility Assistant
This program might not have installed correctly
If this program didin't install correctly. try reinstalling using settings that are compatible with...
Read more
I have Windows XP on my computer and I am having an error message after my PC comes to complete start-up and we are on Screen XP which states that it cannot discover amiyazam.dll. How can I resolve this?
Read more
I have tried to install Gears of War on my PC but each time I set up Equipment of War on my PC, after the set up, a web page appears with an image. When I click the page the following error message appears:
“Computer/Program Files/Microsoft Games/ Gears Of War/ Binaries/ WarGame-G4WLive got an issue. Please reinstall the game”.
I've removed and reinstalled the video game about 6 times to with the same result. Can anyone assist me to identify the problem? Thank You
Read more
