Archive
I need to install AutoCAD CIVIL 3D 2012 for my class with my 32-bit Windows XP PC. I used CIVIL 3D 2010 before and it works fine. I could not install CIVIL 2012 as I always end up getting Error 1406. How can I fix it? And also, can I use objects that I used in CIVIL 2010 with CIVIL 2012? Are they compatible? I need assistance. Thanks.
Error 1406. Could not write value Class to key SoftwareClassesCLSID{00024500-0000-0000-C000-000000000046}InprocServer3211.0.0.0. Verify that you have sufficient access to that key, or contact your support personnel.
Abort Retry Ignore
Read moreI am trying to make a GIF image in Photoshop. I used Adobe Bridge CS5.
When I attempt to open Bridge with Photoshop, I got an undefined error.
I was unable to open Bridge so I try re-installing, but that did not resolve my problem.
What should I do next?
Error
Error 2: Photoshop is undefined.
Line: 1
>photoshop.invokeBridge (false, false, “);
OK
I need to deploy Forefront Endpoint Protection (FEP) 2010. In order to do this, do I have to use System Center Configuration Manager (SCCM)? Please advise.
Read moreI had a problem when starting my Windows XP machine. I keep getting mchost.exe error on startup. This error occurs after an update with McAfee Antivirus. I checked on the Task Manager for this process and kill it. And then I restarted the system but only get the same issue. What could this be? Please help me fix this.
mchost.exe - Application Error
The exception unknown software exception (0xc000417) occurred in the application at location 0x1005f522.
OK Cancel
Read moreI went to the gas station to put some gas on my car. The station used a computerized machine for paying the consumed fuel.
I inserted my card, but I was surprised to see that there is an error message as shown below.
I was thinking why on earth do they have to put an error when customers cannot do anything about it?
Does anyone encounter the same issue?
Do you know what it means?
The exception unknown software exception (0x0eedfade) occurred in the application at location 0x77e73887.
Read moreI am experiencing problems with monitoring some of my SQL servers. I try to find the servers in monitoring mode under Microsoft SQL Server->Computers and it does not work as it is.
Can someone explain what's wrong with this? Thanks ahead.
Read moreI used PostgreSQL 9.1 Server in my Windows XP computer.
It has the application Stack Builder option.
I got an error when trying to install additional software with Stack Builder 3.0.0.
I posted the screenshot of the error I am receiving.
Please send some help so I can fix the issue.
Thank you.
Stack Builder Error
Failed to open the application list:
http://www.postgresql.org/applications-v2.xml
Error: the URL specified could not be opened.
OK
Read moreI used the Terminal Server Management Pack (v. 6.0.6278.22) to monitor my Windows 2008 R2 server with terminal services, but the server does not appear in the MP.
Is this problem caused by MP not supporting Windows 2008 R2 server?
Please advise.
Read moreI have a problem with alterIWnet when starting iw2m.exe and I was told to update aIW2.exe but always had the error below.
I could not continue with the game. Where can I manually download oilrig.ff?
And to which folder should I add this when I downloaded it? How can I fix this problem?
Help please.
Error Error during initialization:
Zone *oilrig.ff does not exist.
OK
Read moreI installed Microsoft Silverlight 3 (3.0.40723.0) on my desktop but it does not get recognized.
Is it absolutely necessary to have the latest version of Silverlight?
Read more
