Archive
Hi guys.
I am working as an administrator of a large network running Windows XP on the desktop, Windows 2000 servers and Exchange. Client gets a message about group policy settings stop him doing so and to check the Event Viewer, when he tries to copies or attaches shortcut to new email and then tries to open it,
There is no problem found when client attaches the actual document. The following error message is displayed:
Error: "Windows cannot open this shortcut because it has been prevented by a software restriction policy. For more information open the Event Viewer or...
Read more
Hi!
During time to run programs, games, I found this error message:
The application is not a valid Windows image
Aphex.exe - Bad Image
The application or DLL C:WINDOWSsystem32oledlg.dll is not a valid Windows image. Please check this
against your installation diskette.
        OK
I'm not good with computers, so I would be grateful if you could explain clearly the problem.
Read more
If I boot my laptop I get a two Bad Image errors at the same time but appears always at boot up time.
I get: C:Windowssystem32atiumdva.dll and also get a: Failed to load CommonRes.dll at boot. After clearing a malware infestation on one of the other forums still having problems with the OS.
I found times out, when I need to run an update it to Service Pack 2 the installation.
Need ideas on these issues.
Read more
I am running win7 32bit, 4GB RAM, Dual 2.66hz CPU since I installed VDJ 7, I sometimes see this warning on the screen when loading a video file. Either big or small vob/mpeg file, it keeps displaying. I follow its steps when I close it down, loads the file with no waveform and plays it. And it doesn't create any effect on the show from the dancers’ side.
Can I do/repair/upgrade to stop this from happening?
Virtual IDJ
Decompressing this file in memory would require 516Mb of contiguous memory.
Your system has only a total of 864 Mb available free...
Read more
Hello community!
I found this error message when I was heading to the programs menu and select HP then updates - I received:
“The computer this program communicates with for update info is currently not available.”
7-12-10 I found nothing for displaying in my image zone program.
Are there any similar issues any one has faced and can help me find a solution?
Help will be appreciated.
Read more
Hi all.
I am receiving this message while I’m trying to uninstall Revo unistaller pro. But at the primary stage I tried spyware and said it was trying to run on startup so it said quarantine so I did, Now I move back to uninstall the program again and crushed with this error 5:
Unable to create a temporary file. Set up aborted. Error 5: Access is denied.
Error
I don’t understand about the reason why it needs to make a temp when...
Read more
Hi all.
A few days ago I had installed Google Chrome on my computer but I am not happy with how it operated.
So I uninstalled it.
Now when I open Windows Mail and I click on a URL link in the message I get this error.
http://theportal.spruz.com/disable/temp.asp
Windows cannot find ‘http://theportal.spruz.com/disable/temp.asp’Make sure you type the name correctly, and then try again. It also opens up in the browser. I think it may be a file association error but I unable to figure it out.
Is there any solution available from anyone?
Thanks for a better reply.
Read more
Hi guys,
If you make an attempt to apply a fix pack (FP) or cumulative client hotfix (CCH) to Lotus Notes on USB you will get the following error message:
It seems that the error message says, the installer is missing some registry keys and does not know, where to install the hotfix. But that´s not illogical, cause Nomad does not create any entry in your registry.
The thing I know is that to upgrade / install fixes on Lotus Notes on USB is to create the necessary registry keys for short time. Unluckily, the value given by the error message above is...
Read more
Hi All
This error message appeared while I was using Outlook 2003.
Can't open default folders
I have tried all suggestions mentioned on this website, but can’t able to fix the problem.
That’s why, I bought Outlook 2007 which fixed the "can't open the default folders problem, but now outlook cannot send or receive and gives me this error:
0x8007000E not enough memory error
OutIook Send/Receive Progress
1 of 2 Tasks have completed successfully
Dont show this dialog box during Send/Receive
Task ‘SiteWizard Archive - Receiving’ reported error (0x8007000E) ‘Out of memory or system resources. Close some windows...
Read more
I recently installed Card Studio 2012 Deluxe.
The installation went well but when running it, an alert pops up with error “An Unexpected error has occurred and the program must close".
I am running Windows Vista 32-bit PC.
Do you have any idea on this issue?
Read more
