Archive
Dear all,
I have set up a network on two computers. One computer is a Dell machine running on Vista, while the other one is an AMD (Advance Micro Device) which has Windows XP on it. My network was working perfectly fine until one day, the AMD stopped sharing files with the Dell. I am not sure how or why this happened. Please help me solve this issue.
The error code is this: “Error Code: 0x80070005 access denied". This error appears every time I try to connect the two computers, along with another error that says, "Windows cannot access \computer name".
I...
Read moreI want to install DirectX 9c on my computer. To do that I needed to uninstall the previous version running on my windows XP.
But there is no Uninstaller for this but I found the registry for DirectX under (HKEY_LOCAL_MACHINE…SOFTWARE…Microsoft…DirectX) and I removed the entry from by running regedit.
But now I get this error saying “An internal error occurred” and the installation fails each time I try to install DirectX 9c using the web installer available on the Microsoft website.
What should I do??
Read moreCannot install the ksplice package through the software center application on Ubuntu. This package includes some advanced features which are highly not recommended for the general purpose use. To use this on Ubuntu download and install the uptrack package of ksplice.
Read moreHello, friends!
I need help with updating my system. I have downloaded an update for Windows Vista but it’s not installing.
I get the Error 646 when I try to install this update on my system.
Windows is showing that this update has been successfully downloaded on the system and when I try to install it, the system restarts as if it is being installed.
But after the loading time, I realize that no update has been installed. The system keeps on showing that the update has failed to install. I first came across this issue on 12th of December 2008, and since...
Read moreWhy my computer fails to connect to another computer on the network which has printer shared on it. Each time I try to print some document using that printer connection failed error occurs??
Read moreHi, techyv users!
I was told that I will get a suitable answer on this website, which is why I am posting this question here. I have a problem with Windows 7. If anybody has any idea about Windows 7 connectivity issues, please share them with me.
The problem that I am facing now is that when I try to connect to my Home Network, the Windows 7 proceeds to an unidentified network.
It tries to identify the network, but after trying for a while, it just gives up. It gives me an error messages saying that it was unable to identify...
Read moreDoes anyone know the reason that why an error with the message “Installation failed” occurs when I try to install a printer on my laptop?
Read moreHey there, you guys!
I have a question about opening two Excel files in the same window. Usually, when I try to open two different files in Excel, they open in two separate windows.
What I want is that when I open a new file, or another copy of the same file, Excel would make the file viewable in the same window.
This way I will be able to stay within the same window and edit two separate files. I was wondering if there is an option in Excel that would help me do that. Any ideas or suggestions will be appreciated.
Thanks...
Read moreAn error occurs saying “Installation Failed” every time I try to install Kaspersky on my computer.
During the installation I see a progress bar on my screen for very small time like for a millisecond, it seems that the installer tries to copy some files on the computer but fails.
Read more
Hey, guys!
I need help in making diagrams in MS Excel. It is safe to assume that only the people who are familiar with excel should answer this question. I want to create a file in Excel and then transform it into a Gephi file. What I want is to make a diagram in which different people are shown. In the diagram, I want to show social connections of people with the ability to add comments as well. How can I make an Excel file in a way that it can also be compatible with Gephi? For instance, I want...
Read more
