Archive
Hello, community.
I am trying to create a new file in Adobe Photoshop Elements 6, size A4.
When I tried to fix the document's size to 300 ppi, I found an error message saying:
A number between 1000 and 256.565 is required. Closest value inserted.
It then inserts 256.565. The file definitely seems too large. If I try to do anything to the file, the computer crashes, and sometimes displays the error message saying:
Move command could not be completed as file is too large.
I also tried to resize the image or create a new file, but I’m not allowed...
Read more
Hey, guys!
NET Framework is not working on my computer. I have decided to post this question here, because I have not been able to find a solution elsewhere. I have done everything that I could do in order to resolve this issue. I have even followed instructions available online, but nothing has worked. I am trying to install NET Framework on my machine, but it is not working. The operating system on my computer is Windows 7 Ultimate. Any help in this regard will be greatly appreciated. The error code that I am getting is...
I am unable to receive emails. The error dialog box shows that I have a wrong password. In other message also shows me advice for user name and password--I have submitted my password XXXXX but it is not responding at present.
Voluntary details:
Computer OS: Windows 7
Browser: IE
Already Tried:
I had gone to email accounts and retyped password. It is possible that I may have altered it from home earlier.
If it is the case I also then might have...
Read more
Hi all,
Can anyone please help with the installation of Adobe Master Collection CS4? I have purchased this software suite but it does not seem to be working. All my attempts to install this software have failed. I am continuously getting this error near the end of the installation, “One or more components failed to install correctly”.
When I click the button that says more information, I get this message: “Error 1603: Fatal error during installation”. The details tab also shows that the problem has occurred in Photoshop, InDesign, Illustrator and Dreamweaver. I am installing this software...
Task <Account> - Sending' reported error (0x800CCC13): 'Cannot connect to the network. Verify your network connection or modem.
What does it mean?
This annoying error is being faced by me for some months and no reasonable solution is still there till now. I faced the problem on using the Outlook 2010 Beta; therefore I only took it as the issue belonging to a beta version. Now I am having the appropriate RTM version of Outlook, but the problem still present.
I own basic account setup with Exchange on...
Read moreHey there,
I received a couple of strange errors while I was trying to load iTunes. The first message told me to register vbscript. So in trying to fix this issue, I entered the command "regsvr32 vbscript.dll" in the command prompt.
After entering the command, I got this weird error message: "vbscript.dll was loaded but the call to DIIRegisterServer failed with error code 0x80004005”.
I simply do not understand what this error mean and how it can be removed. If anybody can help me with this, or at least explain the situation to me, I will be grateful. Thanks in advance!
Read more
The domain represents this message for two users when an option in word of outlook is pressed.
Error: This operation has been cancelled due to restrictions in effect on this computer.
Please contact your system administrator. It looks as all have the joint agreement functional appropriately.
I shall be highly grateful for guidance.
Thanks a lot.
I am Lionel and I am facing a problem with Windows Live Messenger.
The WLM is not uninstalling. Even after the reinstallation, it still does not work. I repeat, the WLMUninstaller does not work at all. Even when I reinstalled the messenger, it still did not work. I have been trying really hard to fix this issue, but nothing has worked. I even tried cleaning my computer’s registry with ERRROREND but to no avail. The closest I got to using it was when I tried to sign in, but then it got stuck there. Please help me. Thanks!
Read moreMicrosoft system Configuration manager 2007 shows me the message as below:
- MP has rejected a policy request from GUID: FC73FB3A-B46F-4409-B468-B90FCCE52F37 because it was not approved.
- The operating system reported error 2147942405: Access is denied.
- Message ID 5447.
- From the sms_mp_component_manager.
Error dialogue box on downloading program:
Hello, I am in need of someone to lend a hand with some problems currently I am facing. Although I can save some files on my machine during downloading software yet at the step of "run", I face this error message: "the file is corrupt, damaged, missing, damaged media or incomplete download. I am also having this problem on trying to update Norton.”
I shall be highly obliged for having support from someone, please. Thanks
Read more
