Archive
I am having an Error 1935 while installing OpenOffice. I am running Windows 7. How can I correct the error?
Read moreI am trying to install Autodesk Building Design Premium 2012, but I received an error during the process.
I tried to run the installation again when it suddenly stops and showed the error, but it just showed the same error message.
How can I fix it?
Could not open key:
UNKNOWNComponentsE44FA6F2A15778B28E2F90A609DADDE2 A4B643700211130409007C5D0680240. Verify that you have sufficient access to that key, or contact your support personnel.
Read moreI am running WinDoctor and there is an error that says “ORUN32.exe is missing” and so I cannot access learn32.dll and pctree32.dll. What should I do?
Read moreThe ACS or the Azure Control Service 2.0 had an update and showed the following messages:
· ACS error codes for failed authentication requests modified
· OAuth 2.0 error codes for failed authentication requests modified
Can someone please explain these new changes? Thanks.
Read moreHi All,
I have an HP laptop with Windows 7 operating system. I got this error message:
"An add-on for this website failed to run. Confirm the security settings in Internet options for potential conflicts."
When I am installing Adobe Flash Player. I tried to go to Tools and then Internet Security and after that all ActiveX settings. Still, I got the same results. Please suggest to me what I have to do. Anyone help for this issue?
Thanks in advance.
Read more
Hi all.
Has anyone experienced with the problems of deploying Flash player via GP? I am seeing this error in the event log:
Product: Adobe Flash Player 10 ActiveX -- Error 2753. The File 'InstallAX.exe' is not marked for installation.
It works fine if it is installed from within Internet Explorer. Does anyone have any ideas? Please share with me.
Read moreHi everyone.
While trying to install the Google Chrome web browser, I found an error code that says "x80040882".
This only occurred while trying to run the installer of Google Chrome browser.
This happens when doing either via double clicking the installer and by "Run as administrator" context menu.
I don’t understand what type of problem is this.
Does anybody have any idea on how to install the browser, and any way to resolve this issue?
Thanks for the response.
Read moreHello experts.
I am unable to get the Winamp player to work. It just keeps saying
"Bad Direct Sound Driver. Please install proper drivers or select another device in configuration. Error code: 88780078
Why this is happening? I have an ASUS motherboard P5AD2-E Premium, with a P4 550 3.4 GHz processor and 2MB DDR2 RAM. Can anyone help me please?
Thanks in advance.
Read more
Hello all.
I am always using simple viewer with Photoshop CS2 and CS3.
Now, I'm trying to install simpleviewer_v1_CS4.mxp to run within Photoshop but it did not appear in the Scripts section. So, I uninstalled it. Then I moved the simpleviewer_CS3 folder into Adobe/Adobe PhotoshopCS4/Presets/Scripts and it showed up but gave me an
"Error 8000"
message after the first picture. Again, I have deleted the folder. I tried the airtight_CS4_scripts.mxp but receive the same error message. So I have uninstalled it. I tried the simpleviewer_photoshop_template_212.mxp but I found an error message saying that I need Photoshop 12.
I have tested it with...
Read more
I found a problem with Photoshop. I've made a *.obj data with a program called "Blender". And when I tried to import the *.obj data into Adobe Photoshop CS5 Extended, it gave me this error:
"Could not complete your request because there is not enough memory (RAM)."
I know about it but my question is: is there a way to solve it or do I really need to get more ram? I have 2 GB at this moment.
Any correct help would be appreciated. Thanks.
