Archive
Hi guys! Can someone please help me on my BlackBerry Smartphone?
When trying to send an email, the Send option is always missing from the mail window.
I already tried to restore my BB but it seems that it doesn’t help at all.
Any ideas about this issue?
Read moreI keep getting this error whenever I tried to add an email account in my Motorola Droid RAZR. I am under Verizon and have been experiencing this for quite some times. The error says “You have already added this email account”. I opened the Verizon website on my browser and tried to check for any solution but I have no luck. Can someone please help me fix it? Thank you.
Read moreI am having error on Adobe Reader with my Windows 7 Service Pack 1 64-bit. The error is stating "AcroRd32.exe - Application Error. The exception unknown software exception (0xc0000710) occurred in the application location 0x773da289." When I click on the OK button in the dialog box, the Adobe Reader will run OK. I have tried to uninstall Reader for few times now. What is causing this and how will I resolve it?
Read moreAs I was trying to start Microsoft Live Meeting session which I received from my email and launch it from Internet Explorer or any browser, I always received an error
I tried to re-download the link from my email for few times now, but the same error occurred.
How can I fix this issue?
Error loading C:Program FilesCommon FilesMicrosoft SharedLiveMeeting SharedRtcRouter.dll.
The specified module could not be found.
Read moreDear friends,
Since I started using Turbocash 3.754 I’m getting this problem. Whenever the cursors touch the upper right corner of the Stock Adjustment window this error appears.
"Error: List index out of bounds (32335488)"
Thanks in advance. I’ll be grateful if you could help.
Read moreHello,
I am using Windows XP Operating System and unable to use the LAN line to connect to the internet. It says an error 1075 : “ System error 1075 has occurred. The dependency service does not exist or has been marked for deletion. ” I guess this means that NetBT has to be set up which cannot be started.
The solutions I have tried based on what I have read from other forums and services seem to not work. I have also tried to fix this on my own using Windows XP installer disk but it was unsuccessful. The...
Read moreHi.
I need help regarding printing an image. I use Windows OS and I have a HP deskjet 930C Printer. I use Kodak Imaging software and load in a document. I create annotations and start printing. I get an error message.
I thought of updating the HP printer driver in the HP website. I only find this error message in this Kodak software, all of them are tif files. I need any suggestions or solutions. Thanks. Here is the error message:
"There was an Error printing to LPT1: for the printer HP deskjet 930C Printer.
There was a problems printing to the printer...
Read moreHi,
The error code 80040154 appears when I am using Windows Update.
I also receive “Class Not Registered” message. An error happens while checking for new updates for my computer.
And windows could not search for new updates.
What needs to be done to fix this problem?
I need a hand. Thanks a lot.
Most recent check for updates 4/17/2010 at 1:43 PM
Updates were installed 4/17/2010 at 2:17 PM
View update history
There is a file in my Drive F: that is giving me problems. It’s an application and its size is 1.08 GB, and it can’t be opened.
This file is useless, so I want to delete it.
The hardest part is I can't erase it. If I right click on the file, Windows Explorer fails.
If I am pressing the Delete key, Windows Explorer fails.
Error created in these positions:
Problem Event Name: AppHangB1
Application Name: explorer.exe
Application Version: 6.0.6002.18005
Application Timestamp: 49e01da5
Hang Signature: 423b
Hang Type: 0
OS Version: 6.0.6002.2.2.0.768.3
Locale ID: 1033
Additional Hang Signature 1: 5410a02a87cec8ffaeea9c4b037fc8ee
Additional Hang Signature 2: 06e5
Hi.
I need help with this problem I am encountering. My database gets an error with the code, Set appWord = GetObject(, “Word.Application”) whenever I run it on the server.
However, it works perfectly fine when I run it on my hard disc. Could you help me resolve this issue? I can’t make any update because of this error.
Thank you in advance for your help.
‘ActiveX Component Can’t Create Object’
Read more
