Archive
Recently I was working on copying a database containing UK Postcodes and their associated geo-location data to one more SQL 2008 server.
The chart restricted a listing of all UK Postcodes along with their longitude and latitude and a Geo Location column that was based on the new SQL 2008 Data Type Geography.
On trying to use the Import/Export wizard to copy the data I had to do the Review Data Type Mapping page and was faced with the error message as follows:
Found 1 unknown column type conversion(s) you are only allowed to save the...
I have just upgraded my Dell XPS M1530 laptop from Windows Vista to Windows 7.
For some time after the upgrade everything was okay and my USB mouse functioned accurately for 24 hours or so and later on I inserted in a memory card and all of a sudden the USB ports went unsupported.
It shows that the ports are ‘disable’ and Windows was unable to identify or recognize any usb port.
Out-of-date drivers may be one of the reasons for this problem, but the required drivers are on my machine at present and I have also adopted the proper sequence for...
Read moreI have just upgraded to the SKYX Professional version.
When connecting to CCDAP5 Software this morning I encountered the following error :
Link to software error, The SkyX Adapter.StarChart 1:COLeException Type mismatch
(800200005) SCODE 80020005
I am unable to get rid of this error message.
What should I do?
Read moreI need advice from someone please. On attempting to upgrade my phone I got the following error message (screenshot included):
“Problem with communication between cell phone and PC
Please disconnect the cable from your cell phone in order and remove and connect the battery. Power on your cell phone and press the Retry button to resume update”
After following the directions(pop battery, retry, etc.) the process of connecting starts but cannot finish, with the error message popping up again. My phone is on 'usb data' mode, not 'sync music' mode, as should be.
The help menu indicates that...
Read moreOutlook 2003 (and previous versions also) have many amazing unknown errors showing often.
I say amazing because they pop up and don’t even tell you what’s wrong.
Most of them seem to take place when using the built-in Hotmail HTTP support.
For example, I am dealing with this error now:
It reads: “The messaging interface has returned an unknown error. If the problem persists, restart Outlook.”
How can I even attempt to fix it if I don’t know what’s wrong?
Any good advice will be greatly appreciated.
Thanks so much.
Read moreThe problem which I am facing at present is I am unable to unzip Karaoke Files. I have many files in a ".zip" file format. I have initiated to unzip some of them with the help of many programs that commonly zip or unzip ".zip" files but surprisingly it doesn’t do the job. I get this error message everytime I unzip the files:
! C:UsersFrostWireDataxxxxxx(KARAOKE)xxxxxxx-.zip: The archive is either in unknown format or damaged
Most of the files are in a routine size for music files so I do not think they have any kind of virus. These files were...
Read moreI need help in fixing this error: Error 1706. Error 1706 comes out when I use Windows Installer and Office 2003. My OS is Windows XP. I am puzzled by this problem and don’t know how to fix it. Any help will be greatly appreciated. Thanks!
Read moreI have been using Outlook 2010 on my machine and it has been running fine until I got this message:
Task '[email protected] - Sending' reported error (0x800CCC0f) : 'The connection to the server was interrupted. If this problem continues, contact your server administrator or Internet service provider (ISP).' I have already disable all add-ins related to Outlook but the error persists. Restarting is the only option that has worked but even it only works for a short while and then the error pops up again and I would have to restart my pc. Closing outlook, even restarting outlook doesn’t help...
Read moreI have a problem here while activating the terminal bundle from Intel. I get an error message like this -
Key sequence C-p t starts with non-prefix key C-p Is that looking for C-P to turn into a prefix command ?
I am confused. Though C-p is bound to previous-line by automatic in emacs and unix shell environment, so is there any other prefix which can work better ? I am using ubuntu operating system and my emacs version is 23.3.1.
The following bundle is activated – (Accessibility completion css cucumber diff erlang git html java javascript lisp markdown power-edit python ruby...
Read moreI am using 32 bit computer. I want to install Windows server 2003 to run Exchange 2007.
Does it require 64 bit computer?
Is there any version which can be applicable for 32 bit? How can I use it in 32 bit?
Read more
