Archive
i just installed windows 7 and i can not install software that worked on windows 98, vista and XP , either from an installation cd or from a hard drive. When i run the stup.exe the pc turns for a while, and then nothing happens, no error message and no installation.
can any one tell me what to do?? thanks a lot!
Read moreHello,
What should i disable for my Samsung galaxy 550 (android) does not connect over the internet to make updates and other things that drain my credit?
Thank you.
Read morei am creating a copy of a dvd with nero 7 as i used to, BUT! for the first time when burning a message tells me the volume on my dvd is too large excess of 5GB!! how an original dvd can have more than 4.7GB?? i do not understand!!
Read morei run an update of my system but i have turned off my pc before the end of update. and after when i turn on my pc it tells me that the following file is missing or damaged "windows/system32/cofig/system" .and then it asks me to do a repaire by inserting the windows xp original cd.but i don't have the original copy.
what should i do please??
Read more
For several days when i want to start windows the following message :
The type of file system is NTFS The volume name is old disk.
The entirety of one of your disks needs to be verified. You may cancel this verification, but its execution is highly recommended.
When I accept the verify it hangs at some point, then nothing and I cannot access to Windows.
I did a Windows repair but it has not detected any error.
If I cancelled the audit nothing happens either.
I have been using Firefox for a while now. I have noticed that Firefox saves my password without asking or taking permission. I have no idea about how to fix this problem and I do not want to password for different log ins to be saved either. Please give me some suggestions about how to solve this problem.
Matth Santos
Read moreHello,
I do not understand this problem. I have around 50 GB space in a drive yet each time I try to install any software in this drive it shows "Not enough disk space" message. If someone knows the solution please help me get rid of this problem.
Arman Hamilton
Read moreHello,
I am facing some troubles due to yahoo messenger. Each time I restart computer Yahoo messenger windows pops up and starts loading. It has slowed down the pc a great deal. However I need yahoo messenger for my use so I cannot uninstall it either. Please help me with this problem.
Evin Gizmo
Read more
I am using windows 7 and the desktop gadgets on my PC were working perfectly. Recently they are not visible correctly. If fact noting can be figured out with them. I do not know what to do In order to make them visible again. Please someone help me get out of this trouble.
Maverick Bozo
I have some hidden files in my hard disk which I cannot find or see. Unfortunately I do not know how to make the hidden files visible. I will be grateful if someone teach me how to make hidden files highlighted. I have lots of space covered by these hidden files.
Spencer Reynoso
Read more
