Archive
I have 3 resources assigned to a task. It takes 30 hours total to complete the task.
Say one resource works for $10/hr, another $20/hr, and third $15/hr.
The cost should be $450 since everyone works 10 hours each on this task.
But MS Project is calculating a totally different cost.
Read moreMy laptop running on windows vista home basic . Total capacity of the hard disk is 250GB. when i calculated total capacity of the files including hidden files and system files is 60GB. free space of the disk capacity is 130GB. what is remaining 60GB used for
Read more
I was using Windows 7 until a few days ago and recently installed Linux operating system.
However, I am having trouble with programs.
The programs that used to run in Windows 7 are not working in Linux.
Why is this problem happening?
Please help me on this issue. If there is an other way to use those programs?
Please notify me.
Angelo Brent
Read moreI am buying MS Office but need it to include Sharepoint Workspace 2010.
I am also looking for the cheapest edition.
Thanks in advance.
Read moreI use HP DV6-610 Laptop. If I play VCD or DVD excepting HD, the picture at full screen does'nt look good not even bright at all. My Graphics details is as follows; Intel HD Graphics:PCI Bus 0, Device2, Function0. Please suggest the way out of it.
Read moreHello,
I am having a problem regarding windows explorer and I need to why this is happening. While I am working sometimes it shows the message that says windows explorer has stopped working and it restarts again it some times causes trouble with many processes and applications. Please someone tell me why is this problem happening and what I need to do in order to over come this problem.
Mickey Nixon
Windows Explorer
Windows Explorer is restarting
Cancel
Read moreI am a security guard and my employer gave me a 1099-misc instead of a w-2. He did not take out any taxes during the year. Should this reported on line 7 of the w-2 as regular wages or should it be on line 12 with business income.
How is it possible?
Read moreHello guys
I'm hoping you can help me because I've heard you're the best. I'm having problem with my Google Chrome – it won't show flash web sites.
Anybody?
Read moreHow can I use the Telnet command in Windows 7? When I typed the command in dos prompt I received following message.
"Telnet is not recognized as internal or external command".
Read moreAnyone wants to display business information in a pie chart form.
At first he arrange data of his institution.
Then he try to present them in geometrical figure.
He do not know how to do it but he is known to pie chart.
What is the solution of it?
Read more
