Archive
I am having trouble with disk clean up process. I have auslogics software installed, and it was working perfectly. It used to solve problems successfully earlier but recently it is not working.
No matter how many times I run to disk clean up process it still shows errors.
Please help me solve this problem.It seems like my auslogics software is broken, however If there is a way to solve it please let me know.
Frank Marlow
Auslogics Disk Cleaner
Find and remove junk files that are cluttering your drives, taking up disk space and slowing down...
Read more
Everything worked fine with Nero8. Someone has used my computer, after that i can not use Nero Photo Snap Viewer, he refuses to view my computer .
What can I do?
Read more
I have windows home premium on my laptop and i Wanted to change the start-up sound but i see that it only has a box that says, play windows start-up sound. My questions is how exactly do you change the windows vista start-up sound since I cannot find it anywhere?
Read more
Excel 2003, in the same file how can i create a link between a chronological list in the sheet 1, so that in the sheet 2 the desired cell is automatically updated once you add a new number in the first list??
Read more
Please some one let me know if Linux operating system is virus protected. I have heard that it is self virus protected so if that is true please let me know. I want to use it in my laptop pc.
abirbu
Read more
I can see "dotted line" report under "Organizational Chart Shapes" option but it is  coming with an arrow head which I do not want.
Please help me as I have to submit my report after an hour.
Read more
Hi
I am a java developer.
Just i want to ask you is it necessary that each try block must be followed by a catch block.
Thanks in advance
Read more
Mozilla Firefox browser has been removed from my computer through add remove programs option.
But it is still installed. I want it to be uninstalled completely.
Is it possible to uninstall Firefox from registry or by using command prompt?
Read more
I'm unable to boot my Meccer Classmate. It displays "Pri Master Disk: S.M.A.R.T.
Status BAD, Backup and Replace
After that it displays a blue screen which reads:
Technical Information:
***STOP: 0x000000ED (0x86FDF938,0xC0000006,0x00000000,0x00000000)
Please help me out.
Read more
I have installed some apple softwares including apple safari browser. They were working perfectly until recently. The softwares has stopped working. No matter how I try they do not seem to work I tried closing the anti-virus and then tried but it did not work either. I tried the open as an administrator command but it did not work either. Please someone tell me what to do.
John Parker
Read more
