Archive
There has been a recent problem in my PC that I need to solve. The brightness of my PC have suddenly faded.
I have tried to reconfigure it with best performance settings and increasing brightness in the graphics properties but things are still the same.
Everything is looking far darker than normal.
Should someone know how to solve this problem please notify me.
Mickey Nixon
Read more
I have to use multi browsers for the sake of my work. Recently there has been a problem regarding the use of multi browser. I do not know what else to do. It is getting frozen due to regular intervals. I need this problem to be solved as quickly as possible otherwise there will be great amount of lose at my work. Please someone help me getting this problem solved.
Matth Santos
Read moreHello,
I have encountered this error message which I cannot understand. I am trying to solve problems on my PC and there has been this error message which I never encountered before. Should someone know what this message informs about please me about it and also the solution to solve the error.
Arman Hamilton
My pc is getting frozen too much lately. I do not know what is causing it but I think it is due to too much load in the hard disk. But I cannot find a way to solve this problem. Should someone know what is exactly causing this problem and why please notify me as soon as possible.
I have an updated version of adobe flash player which I have updated so far each time an update is available. Recently it is unable to run files that it used to run.
Especially the YouTube files which I have to explore all most often. I am in some serious predicament and need someone to assist me in this problem.
Maverick Bozo.
Read moreHello,
I am having some time and location related problem while connected to internet.
Each time I connect my pc to internet it changes my pc time and location. which cause in some serious problem for.
What should I do to solve this problem.
I cannot afford to reset the time each time I turn on the pc.
Please someone give some suggestion.
Spencer Reynoso
Read moreHello,
I am having some problem related to microphone settings. It was working perfectly. I think there has been some changes in the settings but I cannot fix it. So I need someone to give me instruction about how to fix this problem. It is very important for me since I have to talk to many peoples via skype. So please give the solution ASAP.
Benjamin Morgan
Read moreHello,
There has been a recent problem in my DA media player. The sound track is not following the video track properly for which I have to adjust it every time, however most often I am unable to do so. Due to this problem I am in some real trouble. Please someone tell me what to do in order to solve this problem.
Robbie Lucas
Read moreHello,
I have been using adobe acrobat reader for a while to open pdf files. Recently it has not been working properly. For few days I am unable to use acrobat reader to open pdf files for which I have to depend on some other reader. I really want this problem to be solved because there are other functions available in acrobat reader which I do not get in other readers.
Jovan Clayton
Read moreHello,
I clean my temporary file folder temp everyday at least once however there has been few files I am not able to delete. I have marked those files in the error image below. Please help me solve this problem so that I can be sure that there has not been a problem. I will be glad if someone kindly provide with the solution.
Clark Orcus
