Archive
I set the password few days ago and later I could not remember it. I am in some serious problem right and need a quick solution to solve this problem. I really need the issue to be solved real quick, so please someone kindly help me retrieve my password or reset it.
Maverick Bozo
Read more
My working place has WiFi connections but I do not know how to connect to the WiFi network. I need to know and it is very urgent. Please someone tell me how to get connected to the available WiFi networks. I will be really glad and grateful if you do and please do it quick.
Spencer Reynoso.
Read moreHello,
I have got a Bluetooth related error message which I have enclosed below.
I am looking for a solution or cause for this problem.
I have not learned anything about this problem through my searches.
I am looking for someone to identify this problem and kindly notify me.
Please, should someone find the reason behind this error help me getting enlightened.
Benjamin Morgan
Error:
Compatibility issue between a Bluetooth service and Windows
A service associated with a Bluetooth enabled device isn’t compatible with this version of Windows. This service might not be required for this device to work properly.
If your Bluetooth enabled...
I have few softwares and games that I cannot uninstall with directly uninstall operation. If fact some of them do not have an uninstall program. So I need to manually uninstall them. But I do not know the process and I need to uninstall them so that I can make room for some necessary files.
Please help with this problem.
Robbie Lucas
Read moreHello,
I am running little short on my hard disk memory and want to add two drives together in order to further software operations.
I have heard that adding two drives together is possible but I do not know how to do it.
So please someone kindly suggest me about the issue and help me over come my predicament.
Jovan Clayton
Read moreHello,
I have been using g-mail for a while now. My internet connection is little slow but so far it was working properly. Recently it is showing some errors and suggestiing to use basic HTML . I do not understand the problem and asking assistance. Please someone kindly notify me whether this is a connection or problem or something else.
Clark Orcus
Read moreHello,
I need some information. Is it possible to use multiple operating system on the same PC. If possible then will it affect the PC? How far the effects will be applied?
Is it beneficiary for the user? Please let me how it works and then give me some instruction about which operating system will be best for combination.
Dixon Chapman
Read moreHello,
I need to repair few virus affected files which are really important for me.
I have already tried the repair option with my Avast anti-virus, but it did not work.
Now I am not sure what to do.
I have searched for repair tools but could not find any.
Please someone help me recover this files for and help me get rid of the problem.
Joey Fergus
Read moreHello,
I need to recover some files that I have deleted by mistake with other files. I have heard that windows 7 can recover deleted files. If that is possible then it is my only hope. Those files are really important for my work so I must recover them. Should someone know how to recover this files please let me know.
Kenneth Feugo
Read moreHello,
Few days ago I was testing some settings and turned on the smart card option in order to find out what happens.
Now I am unable to log in into my pc and cannot do anything. I need to a way to disable this setting.
Plesae someone tell me what to do to get this problem solved.
Christian Briggs
Read more
