Archive
Instead of renewing our previous certificate we just modified our own certificate for Info Path 2007 working with our cert server. Users get an error messages while opening the published form in MOSS 2007.
The dialog box shows - "Microsoft Office Info path Security Notice" With this, Microsoft is asking for a serious security updates. We check and re-check while updating a new form we published with full security enabled box.
Is there any way to remove the error?
We want our user not to see the dialog box with security questions. Help us please!
Read more
Hi!
We have a problem here to pack Microsoft Publisher 2010. We get an error message here.
The error message is 'Error 1308. Source file not found: Y:ThinAppsProdPublisher 2010EQNEDT32.exe' it pops up when testing the app.
Is there any way to pack this software successfully?
Read moreHello,
I can’t open patient’s file from Osirix database. I am getting an error message while trying this. The error message is “NSCFArray insertObject:atIndex: :attempt to insert nil”
Please someone help me out of this error.
Read more
Hello experts!
I get an error message setting up Openemr4.0.0. It shows an error message.
Here it is below –
Warning: substr() expects parameter 1 to be string, array given in C:xampphtdocsopenemrlibraryclassesInstaller.class.php on line 297
When I attempt to run Openemr I face another error like this - Warning: date() [function.date]: It is not safe to rely on the system's timezone settings. You are *required* to use the date.timezone setting or the date_default_timezone_set() function. In case you used any of those methods and you are still getting this warning, you most likely misspelled the timezone identifier. We selected...
Hi there,
I get an error message when I register an image
( euca-register ubuntu-kernel-bucket5/vmlinuz-2.6.28-11-server.manifest.xml) the error message is like below
Warning: failed to parse error message from AWS: :1:0: syntax error
EC2ResponseError: 400 Bad Request
Failure: 400 Bad Request
Failed to bind the following fields:
Location = ubuntu-kernel-bucket5/vmlinuz-2.6.28-11-server.manifest.xml
Please help to resolve.
Thanks
Read moreHi,
I am a new user. I want to use advanced Weka Segmentation plugin. Though I just installed Fiji and copied the java file from the advanced Weka Segmentation plugin in the folder of Fiji plugin. I get an error message while running the plugin-
C:\Fiji.apppluginsWEKAWeka_Segmentation.java:125: cannot find symbol
symbol : class WekaSegmentation
location: class trainableSegmentation.Weka_Segmentation
final WekaSegmentation wekaSegmentation;
It includes with more errors with saying that the Weka Segmentation could not be found. I have placed the Weka Segmentation file where it should be placed. Though the same thing appears.
Can someone make me understand the problem?
Read moreHello,
I am trying to pull up new vehicle inventory for a Ford dealer. I am using Safari and I get an error message here.
Error 500: Handler processing failed; nested exception is
java.lang.OutOfMemoryError
Please can anyone tell me what this is?
Read moreHello there,
I have installed Daemon tools successfully. After then I get an error while opening any program of my computer.
DAEMON Tools Lite
Error in Command Line.
I then removed Daemon from my computer successfully. Not even a single file is in my computer. I have searched in the internet and found that many people have the same problem out there. And their solutions seem not to work for me. The regedit file can not be open and I tried this –
REGEDIT
[HKEY_CLASSES_ROOTexefileshellopencommand]
@=""%1" %*"
It does not work. Then I tried to solve this by "assoc exe=exefile" then here it shows...
Read moreHi there!
I have just updated Acrobat Pro X from Acrobat Pro 7. When I create a PDF file I try this "epilogue.ps". in that "epilogue.ps" I added a link “(c:\temp\bookmarks.bmk) run”. But its not working. It shows an error message like
Processing epilogue.ps...
%%[ Error: undefinedfilename; OffendingCommand: run ]%%
Stack:
%%[ Flushing: rest of job (to end-of-file) will be ignored ]%%
%%[ Warning: PostScript error. No PDF file produced. ] %%
But it worked well in Acrobat Pro 7. Then what’s wrong with Acrobat Pro X?
Read moreHi,
We have a problem here working with PowerPoint. We can’t save files as we want.
Our designers work with many designs and creative works.
They do very great stuffs, but here is what we came stopped. We are facing an unhelpful error message here.
He has took an screen shot of that error message and clipped it.
Here it is below.
