Archive
My Google Chrome icon Suddenly changed to be Locked Google Chrome icon. I have reinstalled the program, but the lock still appeared.
Here is the picture:
And there is also red line on its frame. Like this:
Anybody know what's wrong with my Google chrome?
I just purchased a new Wacom Intimation, and voraciously unwrapped it so I could start playing with it.
When I went to start experimenting with it, and opened the “Sketch Manager” I’m consistently greeted with an Error 1935.
I’m currently beating my head trying to figure out what the problem is, and definitely cursing Wacom.
I’m running 64-bit Windows, does anybody have a suggestion for this:
Error:
Inkling Sketch Manager Installer Information
Error 1935.An error occurred during the installation of assembly component
{4558CEE0-E4F0-3B56-B15F-4975AED33ABE}.
HRESULT: 0X80070020.
Hi there,
Logos 4 Prerequisites
'Microsoft.VC90.CRT,version='9.0.30729.5570",publicKeyToken="1fc8b3b9a1e18e3b",
processorArchitecture="x86",type="win32". Please refer...
Read moreI just started up Acronis and it started downloading updates. During the download, however I’m receiving this error:
An error has occurred during downloading. Can anybody help?
More information about this error and solutions may be available online in the Acronis Knowledge Base.
To access the online resource manually, enter the event code at: https://kb.acronis.com/errorcode/
Event code: 0x0141002+0x00040014+0x0000FFF0+0x80070020
Read moreNot long ago I upgraded my windows XP to windows 7. I recently wanted to use Putty connection administrator to connect with my Linux based hosting space. I wanted to use putty because it provides tabbed sessions for connecting to multiple Telnet/SSH machines. Unfortunately, I’m running into a bunch of problems using Windows Home.
I had stored the putty database file prior to replacing windows XP with Win7 and then I imported the actual connections in order to use Putty Connection Manager with Windows 7 Home editions. It worked great the first time, but when I tried to connections I started having problems. When I had multiple...
Read moreI’m trying to use Microsoft Self-Extractor on a file I downloaded. I only have one option when I try to extract, so I go ahead and click okay. I keep receiving popup and after the third time I clicked okay I got this error:
Error:
I’m trying to connect android software to my phone but I continue to get an error message that I can’t resolve. It appears that my device can't connect with the actual kies software. However, the software claims that my device is supported. My Computer is running windows 7 and 32 bit Ultimate.
Error
There is a troublemaker in my PC: Kx0t7W4Fgi.exe
Everytime I turn on my PC this program executed automatically and followed by small pop up that contain message "missing blablabla .dll"
How to delete this annoying program??
Read moreI am seeking to install a new HP printer, but and I continuously get an error stating "%1 is not a valid win32 application". The image below is a screen shot of the error. Any assistance is tremendously appreciated. Thanks!
You might be having issues getting or installing Flash Player with Windows Home. This type of problem occurs when you are trying to run a lower version of Flash on your computer when a newer version of Flash Player is already installed.
