Archive
Hello guys, I am getting some error while trying to install Autodesk design review 2008. It says, “Runtime Error 2738.
Could not access VBScript run for custom action”.
I also attached the screen shot of this error:
Read more
One of our customers asked to test and develop some test scripts on VM machine. We typically use test complete tool but never developed any scripts on the VM machine. So, is it good to develop test scripts directly on the VM machine or those scripts should only be debugged on VM machine?  Secondly I am getting problems when I add a breakpoint to any of the test script while debugging and the computer screen freezes and the program should be restarted. I have attached the screen shot of this. Please tell me what can be a possible solution. Read more
I want to use McAfee epolicy orchestrator but when I try to connect to its console using internet explorer 8. It gives me an error that says “The browser you are using is not currently supported”. What should I do?
Read more
Hello guys,
A little of your help is required. I want to integrate FLEX with PHP and I am having issues doing that. May be there is some error in the flash builder but here are the details of what I did so far. I installed flash builder for zend and php and loaded a sample database already available in zend.
But when I tried to configure php service to connect it to that zend database, I couldn’t find any existing php class for the available data services. So I generated one using the flash builder. I entered my credentials correct...
Read more
Today something happened to adobe illustrator and I have no idea what to do now. The brushes, palettes and other tools just disappeared and I get the following error when I try to open previously saved files and I can’t edit them. Any help would be appreciated.
The document 'Print.ai' contains elements that are managed by plug-ins that are not currently available. You can delete or expand these elements, but you cannot manipulate them in other ways. The missing plug-ins are listed below.
Adobe Art Brush Plugin (ArtOnPath.aip)
Art Brush (ArtOnPath.aip)
Read more
Hi, I am using Photoshop elements version 9. It was working well, and I could edit and organize things in it but today after I restarting my computer and trying to run Photoshop elements 9 it ended up in the following error and application failed to open.
I don’t know why this is happening or what to do now.
Please tell me how to start the application.
Runtime Error:
Program:...)AdobePhotoshop Elements9photoshopElementsEditor.exe
This application has requested the runtime to terminate it in an unusual way.
Please contact the application's support team for more information.
Read more
Hello everyone,
I just installed ABP on my 64-bit Windows 7 and I use the debug version of Firefox as my web browser.
The problem here is whenever I open a website which has adds on it. I get the following message:
Please help me to overcome this problem. Following is the screenshot of error message:
NSGlue_ASSERTION
ASSERTION: Want to fire mutation events, but it's not safe:
(aNode->IsNodeOfType(nsINode::eCONTENT) &&
static_cast<nsIContent*>(aNode)->IsInNativeAnonymousSubtree0) ||
sScriptBlockerCount = = sRemovableScriptBlockerCount', file
c:/Users/                                mozilla-central/content/base/src/nsContent
Utils.cpp, line 3625
Click Abort to exit the Application.
Click...
Read more
Hello guys, I am using Microsoft SharePoint Foundation, but I am facing some problems to add new users some online group, and I can’t get a collection of administrators in a certain SharePoint.I get the following error:
Error
An unexpected error occurred
Troubleshoot issues with Microsoft SharePoint Foundation
Correlation ID: 1d068104-6c14-4e4e-a94b-4577e913ca44
Read more
Hello everyone, I am a developer and currently doing a project in VB 6. I have to add some finger print reading capabilities to my software, and for the purpose I downloaded the free fingerprint SDK but I am facing some problems using it. I feed the fingerprint image through digital persona. My application successfully added the image to the database.
It even verified the fingerprint image which means there is no problem in the algorithm but when I open the project again after some time and the following error occurs:
Runtime Error! Program: …int_verification_SDKFFVSDKbinwin32_x86Nffvserver.exe
abnormal...
Read more
I am having some problems installing the GlassFish v3. It asks to select a jdk when setting up the server properties but I don’t find any jdk in the runtime environment. And it ends up in the following screen:
Problem Occurrd
Starting GlassFish Server Open Source Edition 3 (Java EE 6)5 at localhost has encountered. problem.
Glassfish v3 requires a JDK 1.6 end not a JRE Please add/select the correct JDK in the Server properties ‘Runtime Environment section.
OK << Details
Glassfish v3 requires a JDK 1.6 end not a JRE Please...
Read more
