Archive
Sometimes for security reasons, i have to change the ip address. But i think every software can not change the IP perfectly, the original IP can be easily detected. Again some software makes you invisible but they can be a threat. What is the best way to change your IP with maintaining your security?
Read moreHi,
Most of the time my browser gets hanged while browsing while filling up forms or other important works.
In that case, Is there any way where I can fix the error without restarting my browser?
Read moreHi,
I am currently using internet Download Manager 6.09 build 3. I have due dated my Firefox browser to version 11.0. Now IDM is not integrating with Firefox. So how can i do it manually?
Read moreCan't seem to install on my HP with win7,32bit. I get errors that quicken didn't help with their boot download.
Read moreI have a trouble when installing ubuntu. My Personal Computer use 1TB harddisk but it can't be detected. But if I use 500 GB harddisk, it can be detected. Is there any solution with this problem?
Read moreHi i am learning C programming language.
I am currently trying to do some graphics programming on Microsoft visual basic.
But i am not getting any options there for it.
Is it possible to do graphics work using C on Microsoft visual basic 6.0?
Read moreWhat kind of code I should use on C programing that allows the user to type a certain letter to terminate the program and does not terminate it until it is the same letter the programmer asks.?
Read moreI need to know how to use the Oracle language and the C++ Programming or it is even possible to use them together.
Read moreWhat is the best code to explain and perform the while loop on C programming (with output)?
Read moreWhat can I do to change the default color of the Text on C programming, (this should appear in the output window)?
Read more
