Archive
Can someone please explain what is a Local Area Network, an Internet and an Intranet? What are the differences between the three and please cite some other important points to remember. Thanks.
Read moreHi,
I want to know what are the duties of a Database Administrator (DBA) when in terms of getting access privilege. Can you please cite some categories that you can see in Database Management System (DBMS) evaluation and selection list?
Read more
When I am installing Microsoft Office 2007, I get an error message and after that I am unable to continue the installation process.
Error 1935.An error Occurred during the installation of assembly component {68b7c6d9-1Df2-54c1f-C8B3B9A1E18E}.HRESULT:0x800736FD.
I need a solution. please help, thanks.
Read moreHi experts,
I want to test a new program on my windows 7 Operating System but the task scheduler is showing the following error message on the set up:
Task XXX; The task image is corrupt or has been tampered with.
I did not notice any Task Scheduler related problems before
I need a solution. Please help.
Thanks
Error:
Task Scheduler
Task
User_Feed_Synchronization-{1A0FF850-02CB-4088-9D3F-2BC617AC6864}:
Read more
I have just installed IE9 but i am unable to open PDF files in the browser. I have tried Adobe reader 10 and Adobe 9, but both have refused.
Before I installed IE9 i didn't have this problem.
I get this error:
The Adobe Acrobat/Reader that is running cannot be used to view PDF files in a Web Browser.
Adobe Acrobat/Reader version 8 or 9 is required. Please exit and try again.
Need a solution, thanks.
I need an answer. i don't have any idea about the following error message.
I need your help. Please help.
Windows - No Disk
Exception Processing Message c0000013 Parameters 75b5bf9c 4 75b5bf9c 75b5bf9c
Thanks in advance.
Read more
When I am trying to go online with Project Neon I get the following error message:
A problem occurred. The rendering service could not complete your request. <An authentication error occurred.>
Need your help to solve this. Thanks in advance
Read more
Hi Experts,
I usually use CyberghostVPN but this morning after installing Kaspersky Anti-Virus on my laptop the software has refused to work. I receive the following error message from the VPN.
It is currently not possible to connect to the CyberGhost VPN network. Check your firewall settings and make sure that you have an active Internet connection.
Then a notification on the task bar appears confirming that all security programs have been stopped. Kaspersky then shows the message :
Previous application launch failed
Information about the application state at the moment of failure is ready to be sent.
To help us make this...
Hello experts,
I got a problem. Whenever I try to start, the program gives me this error message:
Unhandled exception has occurred in a component in your
application. If you click Continue, the application will ignore this error
and attempt to continue.
An exception occurred during the operation, making the result invalid.
Check InnerException for exception details.
My question is why we need to protect and secure our computer. And also what are the advantages of protecting it from various threats and viruses?
Read more
