Archive
This table shows the comparison of the different browser for compatibility of video feature of HTML 5. Which IE version supports the html 5 video feature? What do we mean by the term " HTML 5 is best supported with IE"?
Nowadays, I am facing a new problem that is very funny but a great problem for me. My problem is Mozilla or another browser stopped after running for one hour. Dialog box stated that internal remote servers are not found. My net connection is okay.
What kind of problem is it and how can I prevent it?
James
Read moreThis diagram describes the fetch-execution cycle. How can i perform another step for multiplication just after the step 4 and what value will be loaded in Program counter, AC and IR?
I am using Ms Outlook but recently change my CPU and now want to shift all those files or data to new one how can i do this, And can i Access Ms outlook latest feature in Linus and it is possible to sign in different mail id in single Ms outlook at the same time?
My blackberry 8520 got problem sum keypads not working and some time display gone and also getting error in surfing Internet service center people saying that its a hardware damage but i facing the problem from the very first day when i bought it so can you tell me what hardware problem it is?
Read moreHow does a UNIX file system control access rights on files for different groups of users & these users interfaces of files system for manipulation files?
what is Trojan horses and how does Trojan horses enter in the OS and start attack?
Read more
I have connnected 20 PC's with Data server, by which 15 PC is connected through wire and other one which is laptop using WiFi as I want to block porn and poker sites permanently. What is the procedure to block these unwanted sites?
Read moreI access odesk on my IPhone but now am getting a problem in accessing the odesk, while running the application. It could have switched off as I using the cell phone network. So tell me if its a virus problem or any one of the application needs to be installed again?
What is the use of MLSLABEL data type, in SQL Server & can Oracle precompiler translate embedded SQL programs into a different procedural language. If yes, then what are the different procedural languages it uses?
Read moreI have a Tata photon USB STICK can I access USB for 2 PC's in one time if yes then which modem, hardware, wires are used for the installation of running the Internet? Tell me in detail how this whole process be done?
