Archive
I have a DI-LB604 Load Balancing Router, and I use to load balance my two internet connections, the sky and globe broadband. After setting up plugging in two connections at two WAN ports, then distributing connection to another switch then to our workstations, we are experiencing down internet connections. Is there any other setting I used to configure in order for this device to perform properly?
Hello everyone,
Hope some one can help me with this. In my workplace I have XP Pro SP2. I had installed Microsoft office 2007 Pro, and I used it with no problems.
About 2 weeks ago my excel didn't open, so the geniuses at our help desk decided to uninstall the office, but when we tried to install it couldn't. Now whenever I try to install office 2007 or 2003 I get error 1935.
Installer Information
Error 1935: An error occurred during the installation of
assembly
'ADODB,Version="7.0.3300.0",PublicKeyToken="B03F5F7F11D
50A3A:,LCID="3081",GUID="eF53030b-882e-4776-b643-eda47
2e8e3f2"", Please refer to help and...
Read moreHow different types of cloud computing solutions affects each other’s performance and data security and exploit functionality over the Internet, rather than delivering full blown solutions which may affect the security of all the information that runs through the web?
Read more
By using Microsoft Exchange server, how can we be sure the reliability that most business requires, since it was mobile, synchronized such as windows phone, iPhone and androids which said to be prone to malwares that increases the risk of spam and phishing threats?
Read moreHow does a single-user and a multi-user disk stripping differ from each other by servicing I/O requests from a single workstation and or several workstations to be sent to a single hard disk or into multiple hard disks.
Read more| What kind of security adapter integration is currently the most certified and supported by most common kinds of directories such as Oracle Internet Directory, IBM Directory Server, Novell NDS eDirectory, Sun Java System Directory System and Microsoft Active directory System. |
Read more
| In Unix Security, Privilege, Shared and Super accounts both can access the most sensitive data, yet since Privilege is the most powerful, is there any sufficient auditing which makes it easy to track down problems and make sure that Administrators only do the role they are going to perform? |
Read more
Hi .
I am having a problem when installing odesk team application.
I am a freelance worker on odesk and i have recently changed my os from xp to win 7.
In win xp i installed the odesk team set up, and it worked perfectly.
But in windows7 while downloading the software in win7 it take long time and does not install properly.
Actually the software is only 3 mb but it downloaded more than 31 Mb.
I need a solution for this.
Read more
I am encoding on my word document. When I saved the document. I accidentally clicked on something and asked to me to save and then I click "yes". Then my documents are full of grid lines. It's kind of annoying while I am encoding texts. How can I remove it?
Ammalyn
I have a newly repaired PC.
When I first use it after the repair, the mouse and the keyboard was doing fine.
After a few hours, the keyboard was down so I used the on-screen keyboard which is kind challenging.
Then after few more minutes the mouse became down as well.
Both of then are not working.
So what I did is I tried to put it on other CPU and it's working well.
What could be the problem in CPU?
Hope to hear from you soon.
Sincerely,
Ammalyn
Read more
