Archive
I was installing a software in my Win XP PC when I got this error message (see below). It seemed that the software used Visual C Microsoft Visual C++ 2005 which apparently wasn’t installed in my PC. Where do you suggest I can get or download Microsoft Visual C++?
Please help. Need the software installed badly.
Microsoft Visual C++ 2005 Redistributable
Command Line option syntax error. Type Command /? for Help.
Read moreI have been trying to hook up my device with HP Photosmart D71000 series.
However, while trying to install the software, I keep getting this error message; software cannot be installed using the ‘Run as’ command.
It also suggests that it should be logged in with admin privileges, tried it but the same error message pops-up.
I have been searching the internet on how to solve this problem but found nothing.
Can someone help me?
Thank you!
Read moreToday, while bench testing an AWAC that I have been successfully configured and tried sending a new deployment set-up (planning) to the instrument, an error message appeared from the AST software.
The error is, "Error 142: unable to enter data acquisition mode, Prolog communication problem when opening file" and "Error 138: Prolog communication problem when reading production configuration, press connect to restore communications". I attempted to do the process again and the instrument seemed to remain confirming the latest data strings at the planned interval to the terminal emulator. It appeared that the wave data strings ($PNORW string identifier) were...
Read moreI purchased a new computer with Windows 7 installed on it. Recently, I hooked my device with a wireless Photosmart Premium Fax 309 series and it worked perfectly fine. However, this is not the case when I installed it on my laptop with Windows XP Professional. I do not know what went wrong because it is running well with Windows XP before. Whenever I am trying to install the program, this message appears, “Fatal error MSI netdevice manager01” and the only thing that I modified on my device is a new router as I joined BT Infinity almost a...
Read moreI have encountered a problem while using IE.
I think by adding non-Microsoft add-ons in IE.
It caused the browser to stop functioning effectively.
I believed that this is the reason why my browser is crashing and getting this error message,
The tab has been recovered; a problem with this web page causes IE to close and reopen the tab.
This is very irritating because every time I use IE, the error message keeps on popping-up.
I need help on how to fix this issue please. Thank you!
Read moreI recently installed Microsoft Access on my computer device. I want to download Northwind Sample Database so I do not have to create one for myself since it is readily available and I do not need an installer to be able to use it. But for some unknown reason the program is not working. I do not know if the problem is with the installation or the program itself. I hope somebody can help me.
Read moreI need help with some issues I am encountering related to connectivity library. Do you have an idea on how to solve the problem such as missing connectivity library and unable to initialize connectivity library? Thank you in advance.
Read moreAn error message appears when I try to connect a webpage from side of client.
I have no idea what I shall do and total surprised with the issue.
Read moreOver the previous hours I have been trying to run every application (except IE) on my Compaq laptop and encountered this error message when I started .txt document: “NOTEPAD.EXE - Bad Image. The application of DLL c:progra~1wi930~1datamngrdatamngr.dll is not a valid windows image. Please check this against your installation diskette”. So I tried restarting my device but still getting error message pop-up and have been clicking OK to continue the boot sequence. I searched the internet and found out that these are Spyware issue. So I installed Malwarebytes and Windows Defender. I run each program but it did not...
Read moreElements of a machine instructions includes operation code,source operand reference,result operand reference and next instruction?what are these and only why are these four?
Read more
