Archive
Will I be able to use my virtual box that I installed in my Windows XP3 using Fedora as an independent application on my computer?
As an example, I want to use it as a write application like file transfer communication, or will it occupy another Kernel space in my RAM?
Please help me on this matter.
Read more
I am having lots of trouble with my server. One problem is the connectivity problem between my DNS and SL.
I cannot play my Snow Leopard unless I use DC as the only DNS server. Another problem is that my SSO cannot function properly after trying every troubleshooting. It regularly asks for authentication before I could log in.
Given that the configuration of my network of Mac is connected to older Windows 2000 Server AD environment.
Why is it that I encounter such problems?
Read more
Hi everybody,
I bought a new Segate Hard Drive, but it didn’t work on my computer which Windows XP Professional was running.
It was invisible in ‘My Computer’ though appeared in ‘Device Manager’. In ‘Properties’, an error message appeared.
ERROR MESSAGE
Volumes
Volume information for this disk cannot be found. This may happen if the disk is a 1394 or a USB device on a Windows 2000 machine.
May I ask what this is about and is there any solution to solve this error?
Thanks in advance.
Read more
Hi, I have a problem with importing a .dll file to my project. I’m using Tao Framework on a Windows Vista OS but when I try to load the file I get the following error:
OpenBVE
Unable to load ‘SDL.dll’: The specified module could not be found. (Exception from HRESULT: 0x8007007E)
If anyone has already successfully resolved this kind of a problem I would greatly appreciate any advice.
Thanks very much in advance.
Read more
Hello everyone,
I’m having trouble with the NOD32 Antivirus System v. 2.7. When I try to start up the program an error message pops-out:
An error occured during N0D32 initialization
WINDOWS NT ver. 4 or higher is required to run this application.
I’m using Windows Vista OS and it’s supposed to be enough for the program to work, but it’s still annoying me.
If someone has already had this problem please post suggestions.
Read more
Hey everyone,
I’ve encountered a problem while I was trying to install NOD32 Antivirus System Remote Administrator 1.0.14 on my Windows Vista OS. I was expecting everything to go down smoothly but during the setup process I got the following error:
“NOD32 Remote Administrator Server Setup
(531) Specific component installation error NOD32MOD_WINNT_ENGLISH_RASRV”.
Does anyone have a clue on how to solve this? Thanks in advance.
Read more
Hello everyone,
Here’s the new problem I’ve encountered: just for fun, I have switched themes on my Windows XP to the classic one and all of the sudden I got the horror message:
RUNDLL
“Error in uxtheme.dll
Missing entry:#64”
I have no idea what it means and I’m sure I didn’t delete anything  by accident but still something appears to be missing.
Please help if you can, I would appreciate it very much.
Read more
Hello everyone,
I’ve recently started operating on Windows XP on my laptop and had no problems until now. But after the last time I’ve updated windows I got this error message when I turn the computer on:
A`NSISu_exe - Entry Point Not Found
“The procedure entry point CM_Get_Devise_IDA could not be located in the dynamic link library SETUPAPI.dll.”
If you have any ideas what could be the problem post here. Thank you in advance.
Read more
Hi everyone,
I got terribly scared in the middle of the night when out of the blue this error message pops-out on me:
System Properties
“There was an unexpected error in the property page:
Catastrophic failure (0x8000FFFF)
Please close the property page and try again.”
The move that caused the error to appear was simply trying to start up System properties from Control Panel.
Why is this catastrophic?
And how do I find out what caused it?
Please help, I would greatly appreciate it.
Read more
Hi there,
I could not move a file on the desktop for a moment last night. The file could not be deleted, moved, copied. And an error message appears.
Error Moving File or Folder
 “Cannot move CIMG0306: It is being used by another person or program.
Close any programs that might be using the file and try again.
‘ERROR MESSAGE’
The computer was trying to reboot but the file still could be worked.
Please help and  thanks a lot.
Read more
