Archive
At first I am giving you a snapshot about my pc:
1. I have got Samsung 120 GB hard disk on my pc and more then 12 GB has been allocated to drive C.
2. I am running Windows XP Service pack 3.
3. I have installed only few software and as a whole it take around 5 GB place in C drive.
4. I am using my pc as a print server and more then ten users are sharing my printer.
After three months of clean service, from last week I am seeing a message that disk space is very low on drive...
Read more
I have never experienced this type of problem before. My internet explorer is opening automatically time and time again. Basically I am using Firefox 3.6.17 and use Internet Explorer occasionally. I guess this is happening for virus attack and checked every drive by kaspersky antivirus and it is a licensed version.
But not getting any virus and nothing has changed. I can’t uninstall internet explorer because I need to use it to open and print some special PDF format documents which is not compatible to any other web browser. I have also searched on the internet for the solution but...
Read more
This is so weird guys, no way I can escape this little yet frustrating problem.
I am running Windows XP on my Acer TravelMate 5542. But the disk checking window appears on each and every Windows starting.
Checking file system on C:
The type of the file system is NTFS.
One of your disks needs to be checked for consistency. You may cancel the disk check, but it is strongly recommended that you continue.
To skip disk checking, press any key within 7 second(s).
I know that this kind of disk checking occurs in case of improper shut down. But the...
Read more
I have a bunch of Microsoft Works(.wps) files that need to transfer as a .doc or .docx file.  But I don’t know how to properly do this.
A site says I have to download wp6rtf.exe, but I found a trial version only.
This is a converter that enables Microsoft Word to view .wps files. I am using Microsoft Works 4.0 and I will be transferring the files into my Microsoft Word 2007. When I tried converting the file, it looks strange.  It seems that the converting process is not successful.
Does anyone knows how to properly format a .wps into .docx? Do...
Read more
I am an IT professional and can solve the common hardware or software issue. Very often my friends come to me with various types of problem and so far I have satisfied all of them more or less. But in this case I can’t find any solution.
Yesterday one of my friend came to me and told me that he forget the login password of his Compaq notebook which is running on Windows XP. I have tried to enter as administrator but it is also protected by password. I don’t know any other option to access the OS. Please help...
Read more
I have been using Acer Aspire 1410 model laptop for the last one year, which is a gift from my elder brother. Accidentally, the adapter has been damaged at least two weeks ago and I tried to replace it with same model of the adapter but was unable to find it in the local laptop repairing shops.
At last I bought an adapter, which belongs to HP notebook. I bought it on the recommendation of the technician. He told me that the power supply system would still be the same, though it is not the same model. But after using...
Read more
Hi, all of you HP Pavilion users I need your kind attention to solve my problem.
I can’t turn my pc into standby or hibernate mode. Previously it was completely ok and last time I used these options about five days ago.
I am not sure exactly when the options vanished, but I have seen it this morning. There is no power option under control panel, and taskbar icon is also missing. I have installed some Windows update about three days ago, and I am using windows 7.
I thought this is a problem of graphics card but NVIDIA graphics driver is...
Read more
Hi!
I am Tony Lucas, and I am very much into Photography and Photo Editing.
I have been using Adobe Illustrator for months now, and suddenly I am caught up into one of its keys to work with.
Yeah, I am talking about the shift key. It was working fine, but I just don’t know if there are keys I have pressed to make it act up.
I am using the shift key to detain several objects, constrict sections, scale objects and the likes.
I guess this should be Adobe Illustrator’s issue, and not the keyboard as the other functions of shift key is...
Read more
Somebody please tell me what to do. I can’t access BIOS system of my Sony VAIO EA24FM/W.
I am trying to access BIOS by pressing the function keys including Esc, Del, Ctrl + Esc & Ctrl + Del, F1 but nothing is working.
After showing the VAIO logo operating system starts loading.
While I am pressing Esc, it reboots the computer. I am running Vista and want to install Windows 7.
Only F8 key is working which says to choose safemode and other options also available which are not related to BIOS.
Is this a virus case or any kind of damage occurs in...
Read more
Hi my windows XP computer says that the Win 32 application has failed to start and I face serious issue with my computer like it hangs .Becomes very slow at times when I open multiple applications and its totally weird to work with my computer with this trouble popping out every time .
I have also tried to clean up the virus using PC Clean Up software so  hope that this problem may not be because of virus and I have also made sure that this problem did not arise after installing any recent software by removing them. From my...
Read more
