Archive
I freshly installed a new game I bought yesterday. After a successful installation I try to run it but I got this error message. I ask my friend to installed it to his computer to see if the error would still exist, luckily it work just fine. I try to troubleshoot it by myself but nothing works.
Here are the things I’ve done.
  1. I uninstalled the program, reinstalled it again
  2. I try to run it by right clicking and choosing run as administrator
  3. I installed a new patch for the game in the net and installed it
  4. I try to change the compatibility mode...
    Read more
I’m making my own personal site for my portfolio. I’ve already created my mock-up design for the site. Slice all the necessary images and convert it into HTML and CSS code. Now, I want to create a dynamic menu which I can modify the menu, add more menu and submenu, i think this is possible but I don’t know how to code this. I’m new to PHP and I need some expert to provide me sample PHP script on how to do this. Kindly also include how to make a database for this. This is going to be a...
Read more
What’s going on with my windows task manager?
All the menu and the tab menu are hidden only the processes are shown don’t know what to do. I wasn’t able to change to another tab such as the Application tab.
I have been troubleshooting it by myself, but I failed. What would be the reason?
I thought it was the cause by virus or any malware, but my avast scanner doesn’t detect any threat.  My computer doesn’t show any error, all the programs seem to work fine.  I think I mis-configured something or deleted something.
I have a screenshot of my windows task...
Read more
This thing is always bothering me whenever I use the computer!
Drive C: and drive D: are my current drive file holder. All the files are saved there. I deleted some files due to the amount of data stored in my drivers. The computer always warned me about 'Low disk place" icon on the system tray;
To free space on this drive by deleting old or unnecessary files
Low Disk Space
You are running out of disk space on Local
Disk (C:). To free space on this drive by deleting
old...
Read more
I need a free website email extractor and so far I found only one good from the internet. I still required three to be installed on my computer. The thing is every website email extractor, I see is very expensive. Also, their trial version is not letting me copy and paste the results.
It's hard to collect email addresses manually and it is very time consuming. Unlike if I have an email extractor, I can just leave it running and just do other task.  If you know something about what I need please let me know. I have...
Read more
For three years that I've been using with my laptop computer the message above with S.M.A.R.T occurred few weeks from now.
As anyone does with their computers like internet surfing, software installations, upgrading drivers and booting are done as my system routine. Scanning the drivers and restoring the factory settings.
But I have noticed this message every time I turned on and start the computer before the Windows logo is loading. At first i took it for granted but lately i started to get worried.
What is S.M.A.R.T doing with my laptop? If this message-alert will not take for an action what...
Read more
It all happened when I do dual booting. (Windows XP and Windows 2007)
This prompted a message appeared when i started the computer after booting.
Locading Operating system ...
DISK BOOT FAILURE, INSERT SYSTEM DISK AND PRESS ENTER
I already checked the boot devices and it is placed properly. The next move was to reinstall the Operating System. I carefully set up the boot devices and placed it properly, arranged, detailed by detailed. I followed the prompted instructions to make sure that no errors will come out upon installing. When the installation is done and the computer is started,...
Read more
Hi
I have an old a desktop with Intel Pentium 4 ( not core duo or core 2 duo just plain old Pentium 4 ) with 1GB of RAM installed and 80GB HDD placed inside of it. I installed Windows XP Pro 32 bit with Microsoft Office 2003 but several days ago I tried installing Office 2007 trial by choosing upgrading options from Office 2003.
The installation works fine without any problems whatsoever. Unfortunately,I found out after installation that my desktop runs very slow every time i tried to open Outlook 2007. Outlook 2007 manage to migrate the Outlook settings from the...
Read more
I have a problem regarding Pointsec installed in Panasonic Toughbook CF 19 with Windows XP for Tablet PC installed in it. The installation itself is working wonderfully but the problem lies after installation.
Every time I tried to turn on the laptop, it will take long time to do that in fact for several times I have to turn off and turn on again to make it enter Windows normally. Sometimes, I was faced with blank screen whenever I tried to turn on the laptop. This happened only to people using Panasonic Toughbook apparently since other users using different brand...
Read more
I just got a new laptop Dell Latitude E6420 with Windows 7 Pro installed in it. It has an i5 Core. I'm having a problem to install Pointsec from Checkpoint in it.
I know Pointsec have problems with i3, i5 and i7 processors. I follow the work around from Checkpoint by disabling Hypertrading capability and set the SATA Operation to ATA mode. If I didn't use the workaround, Pointsec simply won't install. It will give an error message that said Pointsec installation cannot be completed because it was interrupted. After the workaround, the installation process works without any problem at...
Read more
